20 Most Recent Proscan PLDED3257A 32" LED TV 60 Hz, HDTV Questions & Answers
My 32" ProScan plded3257a-b won't turn on. Red indicator light turns yellow when power button pushed. Is this bad news for this trusty companion?
Hello John West, I just checked MY first recommended SPARES dealer (link will be at bottom: "SHOPJIMMY" for stock... on your ProScan plded3257a-b... They are out-of-stock WHICH MEANS MY 1st GUESS is a popular GUESS. Your main POWERBOARD is divided into specific power sections... MOST LIKELY... you could open your set and (I DO NOT recommend) be able to measure... the PRINTED voltages around the out-put points WRITTEN around ON the Printed Circuit Board... (but these boards are in-expensive and the risk of injury is not worth the POTENTIAL savings (assuming you have the requisite skills & materials). Always check your OWN BOARD NUMBERS...!!! Never force any connections...!! Take lots of pictures ... put EVERYTHING EXACTLY BACK. My first and ALWAYS recommendation... always protect delicate SEMI-CONDUCTORS by wearing anti-static wrist straps... A tiny static spark you might not feel is sufficient to RUIN the diodes in your cars ALTERNATOR (honest... for reals). Second serious precaution... Use shopjimmy, amazon, eBay or worse... Searspartsdirect.com... (at page bottom) Never rely on anything but your OWN circuit board numbers. Serious ELECTRONIC technicians always take STATIC PRECAUTIONS... and turn off the power (when-ever possible). It is not improbable that the mainboard is your issue... but compared to a "QUALIFIED" (good) home repair technician... It is a mistake you can afford about 5 more times... and if you can go BACK to your ORIGINAL FAILURE condition... you are doing fine (excellent start)... Most "home technicians" aren't even good. As far as I'm concerned... these packs are too cheap to recommend live power tests (YOU can get seriously ZAPPED)... If the POWER BOARD does not immediately power up... I would suggest you assume 1 (one) of two (2) things... 1. Your "NEW" board is also bad (or you did not try to select "sources" when you installed it... (been there.. did that). 2. It was actually your MAIN-BOARD that needed to be replaced. Buy one.... TRY IT. Hey... if you like the set... so you end up with a couple of spare packs... properly handled & stored they will only appreciate in value). Ill-advised activity... (voltage testing) If you own a decent volt meter... and you can look CLOSELY at the TEST POINTS... YOUR POWER BOARD voltages are printed on the circuit-board OUTPUTS: Just keep in mind... you can get hurt... while causing more damage... with careless handling!! Take photos... Work safely... Check your numbers and ALWAYS wear ESD (static) wrist bands... TV Parts Universal TV Stands DLP Chips ShopJimmy Water Filters Lawn Garden Appliance Parts
11/16/2016 2:14:47 AM • Proscan... • Answered on Nov 16, 2016
Proscan plded3273 sky remote rev8 need code
If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily. http://remotesearch.blogspot.com/ http://electronicshelponline.blogspot.com/ http://electrohelponline.blogspot.com/ Type in the brand name of your device, in the search box [at the top right] of the display window, and press enter to get all related posts. It will make surf easy.
1/9/2015 8:09:53 AM • Proscan... • Answered on Jan 09, 2015
How do you repair or replace powersupply on proscan modwl plded3273a
Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time.
10/2/2014 9:00:31 AM • Proscan... • Answered on Oct 02, 2014
My tv is blinking a blue light when I try to turn it on along with a popping sound.
It sounds like there may be an issue with the power supply or internal components of your Proscan PLDED5030A-RK TV. The blinking blue light and popping sound could indicate a malfunction that is preventing the TV from turning on properly.
Here are a few steps you can try to troubleshoot the issue:
1. Unplug the TV from the power outlet and leave it unplugged for at least 10-15 minutes. This can help reset the internal components of the TV.
2. Check the power cord and connections to ensure they are secure and not damaged. If there are any visible signs of damage, such as frayed wires, replace the power cord.
3. Try plugging the TV into a different power outlet to see if the issue persists. This can help determine if the problem is with the power source.
4. If the issue continues, it may be necessary to contact a professional technician or the manufacturer for further assistance. They can diagnose the problem and recommend the appropriate repairs.
It's important to exercise caution when dealing with electronic devices, especially when there are signs of malfunction such as unusual sounds or lights. If you are unsure or uncomfortable with troubleshooting the issue yourself, it's best to seek help from a qualified professional.
3/22/2024 11:46:39 AM • Proscan... • Answered on Mar 22, 2024
2answers
How to stop a proscan TV to stop going from red blue green yellow black white
Download the manual from PROSCAN 55? UHD LED TV ' Proscan (proscanvideo.com) and see section 13 (Troubleshooting Guide).
11/8/2023 7:17:45 AM • Proscan... • Answered on Nov 08, 2023
My Proscan turns on , sound is good .I see only a flicker of the picture in the dark room ? what can i do ?
If it was my TV I'd recycle it then buy a name brand set, Proscan sets are plagued with issues.
10/23/2023 9:24:37 PM • Proscan... • Answered on Oct 23, 2023
How do I get a Proscan replacement remote to work?
If it is a copy remote for the Proscan Model you have, it should work when you insert the batteries. If it is a Universal Remote, you need to put the Proscan Code into it.
8/26/2023 12:02:17 AM • Proscan... • Answered on Aug 26, 2023
Proscan Sound Bar PSA3713-C. How to reset without a remote.
Question edited for clarity. You can't. Just buy a replacement remote! https://www.google.com/search?q=proscan+sound+bar+psa3713-c+replacement+remote+control ..
6/6/2023 2:30:00 PM • Proscan... • Answered on Jun 06, 2023
I have a Proscan Elite tablet and DVD Combo. It has sound but no picture?
There is some troubleshooting in the link, but it is a budget unit that sells for around $90. If it has outlived its warranty, you just replace it. If it is within warranty, claim on it. They aren't really repairable. https://www.google.com/search?q=proscan+elite+tablet+and+dvd+combo+no+picture+only+sound ..
6/5/2023 6:18:13 PM • Proscan... • Answered on Jun 05, 2023
My proscan elite peltdv1029 combo. I locked it by accident and have no password help!
It is a standard Android Hard Reset. You will get an option to backup your data. https://www.google.com/search?q=proscan+elite+peltdv1029+factory+reset
3/8/2023 1:49:38 AM • Proscan... • Answered on Mar 08, 2023
Does a proscan model PLED5544U have a reset button
The Proscan PLED5544U is a 55-inch LED TV. While it doesn't have a physical reset button, there are a few ways you can reset it:
  1. Unplug the TV: Unplugging the TV from the power outlet for a few minutes can help reset it. This allows any residual power to dissipate and can clear any minor software glitches.
  2. Use the remote control: Press and hold the power button on the remote control for at least 10 seconds. This can sometimes reset the TV.
  3. Use the menu: If you can access the TV's menu, you can try resetting it through the settings. Go to the "Settings" menu, then "System" or "General" settings. Look for an option to reset the TV to its factory settings.
If none of these steps work or if you're experiencing other issues with your TV, it may be best to contact the manufacturer or a qualified technician for assistance.
2/27/2023 6:07:50 PM • Proscan... • Answered on Feb 27, 2023
Proscan Tv/dvd magnovox universal remote codes
Here are some Magnavox universal remote codes you can try to use with your Proscan TV/DVD combo:
  • 11963
  • 11603
  • 12746
  • 12260
  • 10587
  • 12070
  • 11990
  • 10178
  • 10030
To program the Magnavox universal remote to control your Proscan TV/DVD combo, follow these steps:
  1. Turn on your TV/DVD combo and point the Magnavox universal remote at it.
  2. Press and hold the "Code Search" button on the remote until the LED light on the remote turns on and stays on.
  3. Press the "TV" button on the remote to program the remote to control your TV.
  4. Enter one of the codes listed above using the number buttons on the remote. The LED light on the remote should turn off if the code is accepted.
  5. Test the remote by pressing the "Power" button to turn on the TV/DVD combo. If it works, try other buttons on the remote to control your TV/DVD combo.
  6. If the first code you entered doesn't work, repeat steps 2 to 5 with another code until you find the correct one.
If you are still having trouble programming your remote, consult the user manual or contact the manufacturer for assistance.
2/26/2023 4:02:08 AM • Proscan... • Answered on Feb 26, 2023
I have a proscan elite tablet and dvd combo. Some how I locked it. Help!
If your Proscan tablet and DVD combo is locked, you can try the following steps to unlock it:
  1. Restart the device: This is the simplest and quickest solution. Simply restart the device by holding down the power button until it shuts off, then turn it back on.
  2. Check the lock button: Some devices have a lock button that can be used to lock and unlock the device. If your Proscan tablet has a lock button, check to see if it's in the locked position and adjust it if necessary.
  3. Reset the device to factory settings: If restarting the device and checking the lock button don't work, you can try resetting the device to its factory settings. This will erase all data and settings on the device and restore it to its original state. To reset the device, you may need to access the settings menu and look for an option to reset the device or perform a factory reset.
  4. Contact the manufacturer: If you're unable to unlock the device using the steps above, you may need to contact the manufacturer for further assistance. They should be able to provide you with more specific instructions on how to unlock your device, or if necessary, repair or replace it.
I hope this helps! Let me know if you need anything else.
2/12/2023 6:26:49 PM • Proscan... • Answered on Feb 12, 2023
2answers
Proscan 3373A. Hard reset for 3373a Proscan
The model doesn't exist. All question need 'make model (what it is)', first 3 words and in that order. "channel button". is it a television? Reset would be in Settings / General. You have the Remote? All sets need a Remote. https://www.google.com/search?q=proscan+3373a They make a lot of stuff! Proscan Video - TVs, tablets, DVDs, and camerashttps://www.proscanvideo.comProscan manufactures and distributes quality electronics & appliances such as Televisions, Tablets, DVD systems, portable and home stereos, and cameras.‎Contact Us · ‎Television · ‎About Us · ‎Manuals & Downloads Proscan Tablet reset, Standard Android Hard Reset.
1/29/2023 6:26:15 PM • Proscan... • Answered on Jan 29, 2023
How do i turn down a proscan tv without remote there's only a power button on the i tried everything ...And ideas
No MODEL details and one of my favourite manual sites says they have 400 Proscan manuals. They ALL have basic controls for On/Off, Volume UP and Down and Channel Up and down. Get behind and at the sides the television and your will see them. This model has them on the right edge. https://www.manualslib.com/manual/484183/Proscan-42lb45q.html?page=9#manual also read this. You need a remote. https://www.fixya.com/support/r29872378-universal_remotes_no_facsimile_remote ..
12/8/2022 5:22:19 PM • Proscan... • Answered on Dec 08, 2022
Have a plcd3992a proscan tv. It cuts on says proscan then disappears. What to do ?
I'd recycle the set and buy a better brand like LG, Samsung ect. Proscan TVs are plagued with problems and in most cases not worth repair
11/10/2022 10:29:12 PM • Proscan... • Answered on Nov 10, 2022
Proscan PLDED3257A 32" LED TV 60 Hz, HDTV Logo
11 questions posted
Top Proscan Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Proscan Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Proscan Televison & Video
Most Popular Question
32 proscan plded3257a b turn red
  • Televison & Video
