Garden Logo
T
TommyBeverage Posted on Jun 16, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Why does the blade turn off while backing up on my CubCadet zero turn lawn mower?
  • David Bugden
    David Bugden Jun 16, 2018
    Wow I was answering a question in another form and it posted here... too many windows open... your issue isn't an issue it's a safety feature as most accidents happen when in reverse.
David Bugden
Level 3:
Master:
  • Master 431 Answers
  • Posted on Jun 16, 2018
David Bugden
Master
Level 3:
Master:
Answers
431
Questions
Helped
132728
Points
1217
Your missing the clip that holds the nut... there is a keyway under the blade housing that will strip if there is an issue... don't want that girl flying off during mowing. There may be a small cotter pin that goes through the bolt or a cup edge that protects the bolt from coming loose when it contacts grass.
vince
Level 3:
  • Garden Master 2,530 Answers
 vince
Garden Master
Level 3:
Answers
2530
Questions
0
Helped
749093
Points
8845
It's a reverse caution switch so you don't back over someone with the blades running. You can google what it does and where it is.
best to you
5 Related Answers
#1 Taper
Jim Parker
  • 1041 Answers
  • Posted on Jun 09, 2009
SOURCE: toro mower dies when i try to pull out
Disassemble carburetor and spray with carb. cleaner. Use a Den Tek Brush,
(http://www.drugstore.com/products/prod.asp?pid=165357&catid=1152), to clean the small portals in carb. Make sure that the small screen is free of debris. Reassemble and start.
If this doesn't work, then you will need to buy a carb. kit and replace all the appropriate parts.
Jim
Anonymous
  • Posted on Jun 29, 2009
SOURCE: Sovereign SLM 1500 lawn mower blades have stopped turning
The belts are available part number is SV150. Call ALM Manufacturing 01423 797208 for advice/stockists.
Dwain Pippen
  • 377 Answers
  • Posted on May 07, 2010
SOURCE: CubCadet 1554 - won't start!
If you hear the PTO click when you turn the ignition on, sounds like the PTO button is pulled out like you were engaging the blades. The engine will not start if the PTO button is pulled out....
Anonymous
  • Posted on Aug 23, 2010
SOURCE: Craftsman riding lawn mower 15HPOHV model 28N707
14.5 craft riding lawn stop moving i dont know what to do
Anonymous
  • Posted on Nov 24, 2010
SOURCE: Craftsman zero turn - blades won't engage
The PTO switch contacts to operate the clutch that starts the blades is defective. I have replaced mine and the new one just failed again. Sears must know this is a defect problem but so far they are quiet about the problem
A diagram of the transmission on a cub /zero turn/tank
Michael, The dealer may print the diagram off for you, just try asking them nicely. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Cub Cadet Riding Lawn Garden Zero Turn Tractor transmission diagram Google...
Cub Cadet Riding Lawn Garden Zero Turn Tractor transaxle diagram Google...
1 Hydrostatic Garden Tractor transmission rebuild 1 of 4 Hydro Gear
https://www.cubcadet.com/wcsstore/CubCadetCatalogAssetStore/Attachment/owners%20manuals/residential/ZF50_02005033-08-1.pdf
1helpful
LTX 1040. Why doesn't blade lever move when engaging blades?
How's the cable?... when you pull back on the lever, do you have tension?
1helpful
I hit a metal pipe with my cub cadet zero turn lawn mower today. Now it smokes under the deck when I engage the blades and it is not cutting the grass. Have I ruined my mower?
You'll need to look under the deck w/ the mower not running and see why the blades aren't turning. Most likely something is bent (maybe blade) and hitting something. The smoke is probably from the belt slipping and getting hot.
I have a cub cadet rzt 50 with a kawasaki 22hp engine it cranks and runs fine for a while and then sounds like its running out of gas, I shut the pto off and it eventually quits running, I pull the choke...
PDF]OPERATORLS MANUAL - Cub Cadet
https://www.cubcadet.com/.../CubCadetCatalogAssetStore/.../own...Cub CadetRZT Series Tractor - Model RZT50VT. Form No. 769-04647 ... Please read this entiremanual prior to operating the equipment. It instructs you how to safely and ...
Basic Troubleshooting - Zero Turn Riding Mowers (Gasoline ...
cubcadet.custhelp.com/.../basic-troubleshooting---zero-turn-riding-mowe...
Scripting must be enabled to use this site. Support Center. Cub Cadet Website ... Basic Troubleshooting - Zero Turn Riding Mowers (Gasoline Powered). Answer ID 10646 ' Published 01/22/2014 11:27 AM ' Updated 01/22/2015 02:50 AM
2helpful
Cub Cadet zero turn. Cannot get the blades to turn when PTO switch is pulled. Belts are fine and attached. Please help. John
i had the same problem. there was a short in the relay just before the wire gets to to back pulley assembly.
I have a cub cedet commercial tank 60 zero turn lawn mower, and i need to change lawn mower blades. Which way should i turn the nut to take the blades off.
As viewed from the bottom, if the blade turns clockwise, then the bolt should have a left-hand thread. A possible exception would be if the blade cannot slip relative to the shaft. This could be the case if the blade (not the washer) has a D shaped hole in it.
Good luck, Al K
2helpful
Toro 42 " Zero Turn; In tall grass and even in moderate grass it is leaving a double strip of uncut grass, that lines up with the division between the centre blade and both outsice blades, resulting in...
Your blades may be erroded on the edges? Or the center blade hub might be damaged or worn.
good time to inspect all the blades and spindles for wear or damage.
Top Garden Experts
Jay Finke
Jay Finke
john h
