Light Outboard Motor Boat Bass Fishing Saltwater  Base Logo
Posted on Aug 01, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Mariner 25 hp 2 stroke hard to start then quits and won't restart
I replaced the spark plugs, check for water in the gas and cleaned the fuel filter. The fuel is flowing to the carb.
It will be hard to start, when it does start it runs for a few minutes at almost full throttle. When I try to idle down it dies. Then will not restart.
Help!
  • Anonymous Mar 13, 2014
    Has new plugs and wires
Anonymous
Level 2:
  • Expert 77 Answers
  • Posted on Aug 02, 2009
Anonymous
Expert
Level 2:
Answers
77
Questions
0
Helped
46495
Points
254
It sounds like the float is sticking in the carb. Since the carb is higher than the fuel tank it pulls the fuel in by vaccum of the engine. when running at high rpms, it can burn the fuel thats flowing into the carb, when you idle down, the bowl of the carb is filling up with fuel faster than the engine can burn it and causing it to flood. Then when it shuts off at idle it does not want to start back up because it is flooded. To make a long stary short, pull the carb and give it a good cleaning and your problems should be solved.
Anonymous
Level 2:
Champion:
  • Expert 202 Answers
  • Posted on Nov 11, 2011
Anonymous
Expert
Level 2:
Champion:
Answers
202
Questions
0
Helped
59317
Points
460
Put a carb kit in you will get the fuel pump gasket also dont soak carb use carb cleaner in a airasoil can, then blow out set float make sure your gas hose is good and pumps up set air adjust out 1 and 1/2 turns don,t screw down tight b/4 making adjustment
Proper Maintance program for 1986 mariner 150 hp 2 stroke boat motor
The biggie is changing the lower unit oil,, making sure its not getting water inside,, R&R the fuel filter, R&R spark plugs, grease all fittings.. DOUBLE check the steering cables... they rust and corrode from the inside...NOT fun to be in a boat when the steering cable breaks!!!!!
Mariner Outboard Service Repair Manuals by Seloc 1977 2004
Jul 08, 2017 • HP Boating
1helpful
2answers
What should I check to repair this problem? Vehicle has spark and gass flow, but will not fire.
lots of reasons check spark again and fuel to what filter carb? engine problems basically are gas and spark so tells me its gas pull plug squirt some gas 2 stroke make shure its oil/gas 4 stroke gas only in cylinder use a eyedropper or a clear gas line of fuel to put fuel in cylinder put plug back in fire up if starts problem in carb if no start may have jumped timing check air filter may even have a mouse nest in it most people don't drain gas out of carbs for winter drop carb clean bowl with pure white vinegar clean all jets pilot / main reasemble
Oct 12, 2016 • ATVs
I have a2002 evenrude 50 horse out board went out on Father's Day started fine ran a littte while quit started back up chugging died wouldn't start back up took it to my friends boat mech he put a new idle...
Do the basic checks:
Check air filter clean.
Check gas filter clean.
Check spark plug not fouled.
Check spark plug cables OK
Check fuel is correct grade/mix (50:1 for 2 stroke)
Craftsman silver won't start
ground the spark plug to the engine block it should spark. sounds like you need to check the valves and push rods
I left fuel in my 97 25hp mariner and now it won't start. how do i get the bad fuel out of the carbrator. I cleaned out the fuel filter and when and got some new gas and 2 cycle oil and bought some...
The carb needs to be removed, taken apart so it can be cleaned. after sitting, the gas will gum up the inside and stop up the jets. Also, it's not a good idea to use starting fluid on a 2 stroke engine.
Sep 02, 2017 • Boating
I have spark and getting fuel won't start
if its a 2 stroke then you need fuel spark and air to get the bike to start have you got compression? check it by removing the spark plug and put your finger over the hole air try and start the bike your finger should be pulled into the hole if not then a piston ring is either cracked or broken
open the air box and check the filter then clean the carb thats all you need for a 2 stroke
if its a 4 stroke then again check the air filter and compression remember that a 4 stroke doesnt have the oil with the fuel it goes in a separate chamber
hope this helps
John
1helpful
Mariner 2 hp outboard engine (1985) not pumping water
My Mariner 8 has a thermostat fitted. It only pumps water when it heats to normal temp.
If your engine stops, it may be a fuel problem. Check the plug and go to Marine Doctor (a) fuel diagnostics, (b) spark plug diagnostics, sections. PK
Jul 26, 2010 • Boating
1helpful
I have a 18" Craftsman gas chain saw. It will not keep running, after two or three cuts it just stops and cannot be started again until it sits for 15 to 20 minutes. I have cleaned the air filter and...
Try removing the fuel cap for a moment, then try restart. If ok, check the fuel vent for plugging. Check the fuel filter for plugging. Inspect the fuel lines for decay or other damage. Check for spark when it stops--it may be the ignition module failing when hot. Check for sawdust and dirt plugging the ventilation system--blow it out with compressed air. Does the engine 4-stroke at speed when not cutting, but does 2-stroke when cutting? Make sure the chain is being oiled while running. Hope this helps!
Have an old Home Lite chainsaw not used since before I had it running when I had some woods to cut a long time ago. The chainsaw (over 25 years old) won''t start when I try....not sure if it just needs a...
Replace the fuel filter, fuel lines, primer button (if equipped), and disassemble the carburetor, clean, and re-kit. Jet needles are preset at 1-1/2 turns CCW from stops (lightly). Make sure the spark plug fires a snappy blue spark when pulled through. If nothing, ignition parts prices and availability may justify replacing the saw with a new one. If sparks ok, start the engine and let warm up. Open the throttle and adjust H needle CW till the engine speeds up, but still 4-strokes. Proper setting is when the engine will 4-stroke, but immediately 2-stroke when cutting. Let the engine idle and adjust L CW so that the engine idles fairly well, but allows the engine to 'follow the throttle' Hope this helps!
Apr 17, 2010 • Garden
2helpful
3answers
Motor runs for 5-10 min. then starts missing and quits.
Check your spark first,if you do not have spark your problem is the coils-if you do have spark the problem probaly lies withone of your valves getting stuck after getting hot and soonas it cools down a little it closes and then you can restart it till it gets hot again.Hope this helps
Top Light Boating Experts
ADMIN Andrew
ADMIN Andrew
jws1013
john h
Are you a Light Boating Expert? Answer questions, earn points and help others
