Ovens Logo
Glen Gatland Posted on Jun 02, 2018
Rational combi oven, fan is noisy when starting and intermitently makes noise, sometimes sounds as if it is rubbing against metal and other times a lower rumbling noise, question as to possible cause?
5 Related Answers
noffie
Onofrio Taverna
  • 12 Answers
  • Posted on Apr 12, 2008
SOURCE: noisy fan
it has to be replaced the bearings are shot on it I'm afraid well knowen problem in are trade.
barkencoa
Barry Coates
  • 3463 Answers
  • Posted on Jan 02, 2009
SOURCE: zanuisi top oven making noise
Yes , there is a cooling fan located at the top of the oven
It could be the fan blades catching, or a noisy fan bearing.
You would have to access it by removing the top oven cover to check., and yes it could be as a result of having it cleaned.
Plz rate my solution.
Thanks.
barkencoa
Barry Coates
  • 3463 Answers
  • Posted on Feb 09, 2009
SOURCE: noise from fan when electric oven is first turned on
The fans are not normally repairable, but there is no problem obtaining replacements.
On a double oven, there are usually 2 fans fitted.
There is an external cooling fan usually fitted on the top of the oven, you would have to remove the top cover of oven to access it, and possibly the rear panel as well.
Then there is the fan fitted in the main oven compartment.
If you open the oven door as it is working, you should be able to determine if it is the fan oven or the external cooling fan that is the cause of the problem.
If you determine it is the fan in the oven that is noisy, then to undo the fan blade assy, you have unscrew the nut clockwise to remove it. as opposed to the normal way of undoing a nut.
Please rate my fixya solution.
Thanks.
barkencoa
Barry Coates
  • 3463 Answers
  • Posted on Dec 02, 2009
SOURCE: Delonghi ESM465ST Oven Noisy Fan
If it is a fan assisted oven, then you are likely to have 2 fans, an external cooling fan, and a fan inside the oven for ciculating the hot air.
So to answer your query, yes it is a noisy fan you are going to have to establish which fan.
It could be a worn bearing, or the fan blade has come loose.
If it is a worn bearing, thge only cure is a new fan.
Hope this helps with your problem.
Testimonial: "Thank you for that. It's noisy even when the fan inside the oven isn't running (ie, just on convection) so guess that means it's the external fan?"
oven-fixer
  • 7 Answers
  • Posted on Apr 05, 2010
SOURCE: RATIONAL COMBI OVEN ELEMENT GLOWING RED -IS THIS NORMAL?
your oven is electric yeah? the hot air element shouldnt be glowing like that, it glows with the door open? the oven has a over temp stat so if the oven got too hot then it would trip out, if it does then the solid state relays will have to be changed, but if it carries on as normal then shouldnt worry
I have a rational combi oven electric 3 phase model number cd61 can anyone help that when should the oven fan motor start after the oven is on and how to test the motor
The motor should start as soon as the door is closed.
to check the motor, I need to know the s/n. Some motors use contractors, others use electronic motor control.
Apr 20, 2016 • Combi Ovens
2answers
Advantium noisy fan
It is probably the external cooling fan that is causing the problem, as this is usually the first one to come on, and the last one one to stop., and usually, these are located at the top of the unit.
Top Combi Ovens Experts
Kardoc
ADMIN Eric
ADMIN Eric
Jorgie  the...
Jorgie the...
Are you a Combi Oven Expert? Answer questions, earn points and help others
