SOURCE: Whirlpool top Loading washing machine won't spin on spin cycle
If the washer won't finish a spin cycle, it probably means that your timer went bad or stalled. You can take the control panel off and look at the contacts for scorching or corrosion.
SOURCE: LG front load washer/ clothes still wet after final spin
The heavy jacket prevented the washer from spinning at a rapid pace, so I added a heavy bathrobe to absorb some of the water and to balance the load. The washer then spun very quickly and drained out all the water.
SOURCE: nec nw-891 washing machine will not complete the programmed cycle
Apparent malfunction in the timer circuits. Specific Component replacement not available.
SOURCE: lg washing machine gets stuck on the rinse cycle
Check and make sure the washer is draining properly, there is a drain catch at the bottom front of machine, twist and remove cap and clean out any debris you find. Also check and make sure your getting enough cold water to the unit. Also make sure your using HE detergent....If that fails you may have a bad control board.
Testimonial: "Thanks!!"
