20 Most Recent Speed Queen AWS75NW Top Load Washer Questions & Answers
0answers
We have an old speed
Drain valve
2/7/2018 9:05:11 AM • Speed Queen... • Answered on Feb 07, 2018
0answers
0answers
2answers
Whilst on the rinse cycle, it just keeps on
Easy fix, no parts needed mate. Simply look for a loose hose going to the water level switch. The small vacuum hose from tub to switch vibrates off from time to time OR sediment gets into the tube where it attaches at the base of the tub. Remove the hose at the switch in the control console and blow through it to clear any blockage and reattach firmly. Remove the water and retry. With any luck the washer will resume normal duty's. Good Day! If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
9/16/2015 9:03:07 PM • Speed Queen... • Answered on Sep 16, 2015
0answers
0answers
0answers
0answers
2answers
SPEED QUEEN WASHING MACHINE LEAKS WATER WHEN IT STARTS WITH WASHU
check hoses and pump area.
5/14/2013 9:32:06 AM • Speed Queen... • Answered on May 14, 2013
0answers
Clicking sound when washing
Remove the back (or the whole ) panel to check what is the problem
3/26/2013 4:05:59 AM • Speed Queen... • Answered on Mar 26, 2013
2answers
#awm693w,removing agitator to replace seals
Unscew the cap on the top of the agitator, then hit it back and forth with your hand and it will break loose. I just did it to mine today and it has not been of for twenty years.
2/25/2013 7:27:23 AM • Speed Queen... • Answered on Feb 25, 2013
My speedqueen make a terrible noise during the wash cycle, what could that be
It is so common that the washing machine can make terrible noise in many ways and is a common fault. In all occasions it is important that your observation is most important and so is vital to the identification /rectification and solution. If you have noticed that machine is vibrating when it is running then the motor /drum suspension has to be inspected. Since these fittings are located on the underside of the machine it is important that you look for the noise with a good inspection lamp. Manually turn the motor and drum and listen for the noise, if so the motor bearings, the drum agitator shaft and fittings must be checked. Also the suspensions which include the shock absorbers and springs, the body clamps must be checked to be in correct alignment and not changed in position. Tightening of the mounting is also very important. Finally in most cases a drop of OIL or smear of grease on the moving parts cane solve most issues.
Check this link :
http://www.espares.co.uk/advice/washing-machines/a/7/1210/wobbly-washing-machine-or-tumble-dryer.html For replacement of bearings check for tips on this visual link: http://www.espares.co.uk/advice/washing-machines/a/7/1401/how-to-replace-the-bearings-on-a-washing-mach.html
1/24/2013 6:20:31 AM • Speed Queen... • Answered on Jan 24, 2013
Speed Queen AWS75NW Top Load Washer Logo
57 questions posted
Top Speed Queen Washing Machines Experts
Paul Bade
NOEL
NOEL
Are you a Speed Queen Washing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • Speed Queen Washing Machines
Most Popular Question
oil grease leaking into tub speed
  • Washing Machines
