SOURCE: Bose AWR1-1W soundless
get bose to make a warranty replacement or repair, its not a user servicable part, infcat its going to be difficult to find the exact problem even if you REALLY want to open it up, it may also be a faulty opamp on IC not switching.
SOURCE: setup radio presets
1. Navigate to your favorite station
with the UP/DOWN buttons.
2. Press MEMORY once. The
preset choice will go to the next
available one.
3. Within 5 seconds, press
MEMORY again to save the
current frequency as a preset,
or else use the UP/DOWN
buttons to fi nd another preset
number, then press MEMORY
to save it.
4. The UP/DOWN buttons usually
tune the frequency, but when
loading the presets, they navigate
the presets.
SOURCE: I need to know how to change the Preset tuning on a Sony ICF-M350V AM/FM/TV/Weather radio.
Try tuning to the station you want and then hold down the present button you would like programmed for ten seconds... if not then there's always the manual.
SOURCE: Dewalt Radio won't hold presets or clock time
Replace the two AA batteries in the battery compartment.
SOURCE: Don't have a manual or the remote for KLH audio
There should be numbered buttons on the receiver.Set the channel to what you want to preset,then press and hold down the numbered button you want.The sound will probably go away for a couple of seconds but when it comes back on the channel is preset.If you press the band button while you're already on FM and it goes to another FM,you can also preset more channels for FM.There should only be one AM band,then it will switch back to FM.
Good luck! Greg
