Lock-out Function for Children
Lock: In waiting state, press " Stop/Clear" for 3 seconds, there will be a long beep if the
time has been set, otherwise, the LED will display "Left brack equal equal sign right bracket "
Lock quitting: In locked state, press " Stop/Clear" for 3 seconds, there will be a long "beep" denoting that the lock is released.
If necessary, call the Lamona Service Line on 0845 00 60 00 and ask for assistance.
SOURCE: can't use the microwave
To lock or unlock the keypad, press and hold the CLEAR pad for 5 seconds. If this recurs, you may have a power line problem or trouble with your controller. If you suspect trouble and it's under warranty, don't hesitate to contatc GE via ge.com. If you don't have your mower's manual, you can download one at: http://www.geappliances.com/service_and_support/literature/
SOURCE: Panel Locked
Press and hold CLEAR/OFF for about 3 seconds to lock and unlock. Download manual on link below: http://www.abtelectronics.com/images/products/PDF_Files/SCA1000-SCA1001_om.pdf
SOURCE: i lost my manual and dont know how to turn the child lock on or off
To turn the child lock off or on, press and hold the STOP/CANCEL pad for 3 seconds.
You can view or download your owner's manual here.
You will need the free Acrobat Reader to view or print it.
SOURCE: my microwave says "child" and won't play anymore
Not sure of the TT series models but for the NN series models the procedure is as follows:-
If "Child" is displayed in the display window, then the child safety lock is on.
To remove the child safey lock, press the "Stop/Reset" button 3 times in fairly short succession (less than 3 seconds). The time of day or just the Colon sign (:) is then displayed
If you later want to apply the Child safety lock, then, when the time of day (or colon sign) is displayed, press "Start" 3 times (again in short succession).
Hope this helps
Doug
