20 Most Recent General Electric Microwave Oven Questions & Answers
The GE support center in Philippines:
http://www.ge.com/ph/
General Electric... | Answered on Oct 03, 2018
No! this could not be further from the truth, you can buy a microwave test card and check for leakage around the door seals, or take it to a service professional to do a quick test.
General Electric... | Answered on May 30, 2018
The door switch and safety switch is not adjusted correctly or is not operating at all.
General Electric... | Answered on Feb 14, 2018
I would dispose and replace the whole. Sounds if the insulation has been compromised,making it dangerous and life threatening to use.They are now so affordable that repair is only justified on top end units.
General Electric... | Answered on Dec 18, 2017
More than sure, the door micro switches do not work properly, they should be carefully checked.
General Electric... | Answered on Nov 14, 2017
Is the unit heating the food? If not you may have a fubar magnetron tube. But it is fused so you might want to check the internal fuse to make sure it is not open.
General Electric... | Answered on Sep 20, 2017
Either magnetron, capacitor, diode pack or transformer has failed causing a fuse to blow.
General Electric... | Answered on Jul 13, 2017
go to youtube type in your query and you should see a page go through video's and make note of who posted the video ,so you can keep referring to it . Hope this helps you .
General Electric... | Answered on Dec 23, 2015
I see this all the time. In all likelihood the mangnetron has failed, or perhaps even the Power Supply. or a fault that is shutting the system down for safety reasons You need to have it serviced by a reputable service centre/man. Ensure you get a firm "Quote" before proceeding, and remember these days the cost of repair can equal or exceed the price of a new one.
General Electric... | Answered on Aug 22, 2015
most probably main transformer fuse blown. if fuse is ok & supply is ok on transformer input terminels.then replace magnetron
General Electric... | Answered on Aug 02, 2014
Your door safety interlock switches are the primary candidate for this problem. The oven thinks the door is open because one or both of the switches are faulty or out of alignment. When the door is open, NO HEAT. Check em out.
General Electric... | Answered on Jul 07, 2014
There are some good tips on this website
http://www.ask.com/question/my-ge-microwave-runs-but-does-not-heat
Could be the thermal cut-off relay has tripped, thermostat is faulty or very remote chance the microwave generator itself is faulty. Will need the model number to make any further assessment of repair.
General Electric... | Answered on May 01, 2014
General Electric Microwave Oven Logo
336 questions posted
Top GE Microwave Ovens Experts
Poppa Maddo
Poppa Maddo
William Miller
William Miller
Jimmy
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
View Most Popular
GE Microwave Ovens
  • GE Microwave Ovens
Most Popular Question
key pad said shorted needs service part
  • Microwave Ovens
