I have one LOTUS NOTES file. It has .NSF extension. But when I click the file to open, the following message occurs: 'A database error occurred'. I have Sony laptop on Windows 10 Any solution for this issue?
Hi
You can read more such errors and their solution from the given link. This blog will help to analyze the Lotus Notes problems and give you the easy approach to resolve them smartly. This will enhance your knowledge about IBM and the tips to fix them.
Read more:- http://www.nsfsecurityremover.com/blogs/lotus-notes-error-messages/
Thanks
Hi
You can use this NSF to PST converter tool that will solve your problem. The tool Successfully converts NSF to PST file format without causing any alteration. Users get the extra benefit to transfer Lotus Notes to Outlook with its multiple features. Any computer novice user can convert Lotus Notes to Outlook as it is designed with an intuitive graphical user interface that requires no prior technical knowledge. The demo version of the tool cokes for free.
Download now- https://www.sysinfotools.com/recovery/nsf-to-pst-converter.php
Lotus Notes Repair Kit is a compact lotus notes archive repair tool download, powerful and reliable repair solution based on intelligent algorithms developed by Repair Kit engineers. Featuring an advanced file analysis core, it carefully examines the structure of damaged NSF files and uses different approaches to its recreation.
http://www.lotusnotes.repair/
Try a free viewer to see if file is ok.
https://www.freeviewer.org/nsf/
Lotus Notes NSF Viewer FreeViewer
SOURCE: covert lotus notes address book "names.nsf" to an excel file
I just stumbled on this one. Actually it's EASY! Open up your contacts list in Notes, go to the File menu, choose export. You can pick either "Structured Text", "Tabular Text", or "Comma Separated Value". All of these import well into either of those programs.
SOURCE: RRV bucket error lotus notes 8.0
RRV bucket is corrupt occurs when opeing mail file. Unbable to open archieve folder. We are using lotus notes 6.5 version. Pls help.
SOURCE: Could someone help me with lotus notes issue?
Hello!
First of all try these steps
1 Open the "Start" menu and click "Computer" or "My Computer" depending on your version of Windows. Navigate to the C drive.
2 Open the "Notes" folder. Double-click on the "Notes.ini" file to open it in Notepad.
3 Place a semicolon (;) in front of the following two lines to temporarily disable VirusScan: AddInsMenus=NCMenu EXTMGR_ADDINS=NCExtMgr
4 Click the "Save" option from the "File" menu. Close Notes.ini. If the steps do not help you try to use Lotus Notes Fix Toolbox https://www.fixtoolbox.com/lotusnotesfix.html
