Drills Logo
Anonymous Posted on Jul 31, 2009
Light on ryobi 18v charger
The new battery I inserted in the ryobi 18v charger has the yellow and green light on and battery will not charge, other batteries that I have charge just fine?? What needs to be done to rectify this problem
Thomas Ashbarry
  • 1 more comment
  • Anonymous Nov 02, 2011
    I have somewhat similar problem but none of the batteries hold the charge for long. Warranty expired in any case.
  • Derek Carver Jul 16, 2019
    My problem is it seems like when I run a battery down put another one in and as it charge that one that I just took out of it and it will be hot so I have to let it sit before I can use it again which is something I don't like to do when I'm in the middle of a job. I have a 40-volt lithium battery that it was stored for the winter and never charged again I took it back to have it swapped out and they wouldn't let me swap it out without calling Ryobi and still blinks green all four lights blinks two times each. I attempted to boost it with a trickle charge so the charger would pick it up never worked
  • Steven E Hall
    Steven E Hall Aug 10, 2019
    Heat generated during a charging session suggests a bad battery in the pack...likely shorted...it can be fixed by replacing the bad cell, but is not easy for the rookie.
Anonymous
Level 3:
President:
  • Master 1,124 Answers
  • Posted on Jul 31, 2009
Anonymous
Master
Level 3:
President:
Answers
1124
Questions
Helped
411572
Points
4130
More than likely a defective battery sinse the other ones charge fine..
Bring it back for exchange of another one..
Note;
We are helping people here every day on a points system.
If the information provided here was at all helpful,
please be kind and rate well.
Thank you – and enjoy your day ;o)
Ryobi 18v battery charger is not charging
If yellow and green light come on and stay on then your battery is bad if not get a new charger
We have a Ryobi P100 Battery and a P110 charge. The battery became very hot while using it and die very fast. When trying to recharge the yellow and green light come on the charger. What is going on?
It sounds like you drained the batteries down as far as they will go. This happened to me and then I purchased the 18V Lithium-Ion battery and charger. I was able to re-charge the drained battery on the new charger. This may work for you as well. They cheapest solution for you is to just purchase a new battery.
2helpful
Green and yellow lights both stay on and it never
see if your charger is under warranty and have it replaced..yours is bad..
Ryobi 18V cordless drill the yellow and green light is on when charging what does this mean
I have found when I put a battery on to charge and the green and yellow light turn on the battery is low voltage and the charger will not charge the battery ( bad battery)
6helpful
The Yellow and Green light both come on and stay on when I put in a battery to charge !!! This is a Ryobi 18v battery charger model #1423701.....
http://oneworld1.inetu.net/manuals/ryobi/hp1442m_1802m_874_eng.pdf
It sounds like your battery is bad. If yellow and green are on for more than 15 minutes it probably a defective battery pack. See page 8 in the manual.
Ryobi battery charger with a solid yellow and solid green light
I was recently told that the lithium ion does not like cold temperatures so you may need to bring the batteries and charge into a warm location and wait until they reach a warm temperature and then charge them.
Battery charge problems Ryobi 18v
Solution is two fold. Will try the freeze and re charge approach today and do this a few times. The long term soluiton is to purchase two Lithium batteries and a duel chemical charger. Expensive solution but seems it will work.
3helpful
Charger not charging
Just was on a website for Ryobi drills and it states that if the yellow and green light stay on for more than 15 minutes the battery is fried. Couldn't find the link but if you do a search for Ryobi Drill 18 volt you should find the same info. It was as product review from Australia I think.
I also have a problem with the charging of Ryobi batterys. They seem to charge AOK with the green light coming on but the charge does not last at all. Not sure if the problem is with the batteries on the charger.
Top Drills Experts
ADMIN Andrew
ADMIN Andrew
john h
Steve Pack
Steve Pack
Are you a Drill Expert? Answer questions, earn points and help others
