SOURCE: My LG Combi Microwave oven
This is usually caused by either a bad door switch (usually the top one), a loose door switch mount, or a problem on the control panel.
Even though a door switch clicks, it may still be bad inside. Its continuity must be checked.
Door switch or mount trouble can be caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
If you someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
If you think the problem is on the control panel, we repair these nationwide by mail for $39.95 postpaid in most cases.
We're happy to help and we appreciate your thoughtful rating of our answer.
William E. Miller, AS-EET
[email protected]
http://www.microwavedisplay.com
SOURCE: where i get new manual
Go to this link:
http://shared.whirlpoolcorp.com/product_literature/search.jsp
Put in your model number ad search for the PDF manual there. Hope this helps!
SOURCE: Lost Manual
You should be able to find your instructions for use here.
SOURCE: Microwave still runs but is not cooking food
Sounds like a bad magnetron, i would replace the magnetron, Capacitor and Diode at the mag assembly, to be honest it will cost you more to fix than a new one.............
SOURCE: my magic chef micro does not work. I replaced the
In many brands, there is a "mini-manual"
hidden inside the unit behind the control panel or hidden on the left side
behind the grille, which is very helpful when troubleshooting, &
testing.
At
our Web site, we have a video available
showing how to remove a typical over the range control panel assembly in under 5
minutes.
Some questions to help you or someone you know troubleshoot it:
When you hit "Start" to microwave, do
the inside light, cooling fan, and turntable
all come on?
If not, then you probably have a bad door switch or door switch mount and should
see these files:
http://www.microwavedisplay.com/safety.txt
http://www.microwavedisplay.com/disassembly.txt
http://www.microwavedisplay.com/doorsw.txt
If the inside light, cooling fan, and
turntable are all coming on, then the problem
is in the high voltage section, and then the next questions arise:
Any unusual noises? Is it louder or quieter
than usual?
We have a sound clip of what a
microwave should sound like when the cooling fan and high voltage section are
operating here.
A loud buzz, hum, or groan is usually a shorted high voltage rectifier diode,
but a sound like gurgling into an empty
coffee mug is one symptom of a failed magnetron, and yet the mag can be bad
without that sound.
If there's no unusual noise, it may just be a bad connection at the magnetron.
Here are some links you or someone you know can use (in order given) for high
voltage section test help, but read the safety warnings first:
http://www.gallawa.com/microtech/diode.html
(if it is NOT shorted or burned looking, it's probably fine)
http://www.gallawa.com/microtech/mag_test.html
(continuity can be good even though mag is bad!)
http://www.gallawa.com/microtech/xformer.html
Accessing some parts may require you to
pull the oven from the wall and remove the cover.
If so, the installation instructions are very handy, and it's best to have
two
people since the microwave can be heavy and awkward.
For more help from Magic
Chef / Ewave see here or their contact page or order
parts here.
You can download owner's
manuals for many Magic Chef models here.
We're happy to help you with free advice and we'd appreciate your thoughtful
