SOURCE: 1966 Ford Mustang Gas Guage not working
I had a similar problem. In my 1966 Mustang gas tank, the fuel pick-up was on a "float." My float developed a hole, filled with gasoline, and sank to the bottom of the tank, therefore, the gauge always read empty, but the car ran well. All the other gauges of course worked correctly. The repair was a relatively simple soldering job (after removing the float from the tank), but if that is indeed the problem, ensure all the gasoline is drained from the float before beginning the soldering job.
SOURCE: Fuel Level Gage Reads Incorrect
sending unit in tank is bad need to drop tank and install new.
SOURCE: Hello, my 92 Svx fuel
It is most likely the sending unit,the age is most revealing of the situation at hand.
SOURCE: 1997 chevy Lumina my gas
It can be blown back into shape with an air hose and a rag. Sounds like a vent problem, check cap
