SOURCE: black box appears on my element electronics flx-2210 television
HI:
Check your closed caption option in the menu, seems its been turned on to Text option, just turn closed caption option off.
SOURCE: Why is my element FLX-2210 saying so signal
It is saying no signal becuase it is not getting he signals from video source or from the cable. Try it on another cable location in the house, if still the same, then you have problem in the main board.
Please read my guide to understand how LCD TV works.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx
SOURCE: My Element flx 2210 shows "no signal" when it's
It looks like this unit will accept several inputs, and it is not autosensing (detects automatically)
On the side, there is a button that is labled "INPUT"
Push this several times until a picture appears.
The must be something attached to the TV for it to display a picture.
VCR, DVD, anything. If it does not see an input it will display
"NO INPUT"
SOURCE: my screeen has gone white
White screen only / no picture is a sure sign of a failure in the power supply board. Your TV is getting power to the back lights but the control board voltages are not getting through so it is not displaying the picture right. This is an easy repair to do, you will just need to replace the filter capacitors on the power supply board. This Element model is actually made by Funai and is the same as the Polaroid FLX-01911c TV. Here is a repair guide for that model that will show you what needs to be replaced to get your TV back up and running again.
http://www.ccl-la.com/blog/index.php/repairing-a-polaroid-tla-01911c-with-a-bad-power-supply/
I hope this helps you out.
BuddyMc
