20 Most Recent Element ELC-HS321 32 in. LCD TV Questions & Answers
My Element Flatscreen works sometimes.
That you have an intermittent issue in the power supply that at some point in future will become permanent rendering your flat screen DEAD. The time is coming so start saving some bread for the eventuality.
8/31/2017 9:57:22 PM • Element... • Answered on Aug 31, 2017
This message comes up ' V-CHIP BLOCK TV-14 DL' I
Go to the setup menu and find the V chip section and disable it.
2/15/2017 4:46:27 AM • Element... • Answered on Feb 15, 2017
I have aelement tv that I only bought no more than two years ago and I am having problems connecting my PS3 to the tv. I change the source to all of the hdmi channels and the screen stays blue.
Sounds like u have the wrong hdmi lead or try turning off the computer n go to setting on tv and make sure its setup for hdmi hopefully that should work
8/30/2016 5:38:53 PM • Element... • Answered on Aug 30, 2016
My tv 50" element tv flat screen
If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
7/1/2016 3:56:59 AM • Element... • Answered on Jul 01, 2016
How do I program my Charter remote to an Element TV?
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily. http://remotesearch.blogspot.com/ http://electronicshelponline.blogspot.com/ http://electrohelponline.blogspot.com/ Search the site by type in the brand name of your device, in the "Search box at the top right of the Home page display" to see the set-up codes to your device, with different brand remote controls. Programming Notes • If your device does not respond to the remote after trying all codes listed or your brand is not listed in the code list, use the Auto Code Search method to program your remote. • Sometimes the first code that "works" with your device may operate only a few functions of your device. There may be another code in the code list that performs more functions. Try other codes from the code list for more functionality. This is a trial and error procedure; and quiet time consuming. You might have to check different codes said for your device.
3/3/2016 9:15:43 AM • Element... • Answered on Mar 03, 2016
Auto scan issues??
The main system control memory IC fault. Check and replace it. Before replace it, try a hard reset to this set. There are two types of reset to TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/ Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
1/20/2016 2:49:29 AM • Element... • Answered on Jan 20, 2016
Won't turn on
Hi, There may be a number of reasons from a blown fuse to a bad power supply unit responsible for your problem. Please consult some local TV Tech.
1/3/2016 9:37:09 PM • Element... • Answered on Jan 03, 2016
Need code from rcauniversalremote
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily. http://remotesearch.blogspot.com/ http://electro-medical.blogspot.com/ http://electronicshelponline.blogspot.com/ http://electrohelponline.blogspot.com/ Search the site by type in the brand name of your device, in the "Search box at the top right of the Home page display" to see the set-up codes to your device, with different brand remote controls.
1/1/2016 4:03:36 PM • Element... • Answered on Jan 01, 2016
Someone please help me figure out why my elemnt t.v all of a sudden does not have no picture?
There are many reasons behind this problem. Here are some common issues about this problem.
  1. Missing LED's Connection from PCB.
  2. Burning LED's (Back light)
  3. No current on back lights.
  4. See in sun shine or torch light, If display show and lights are faulted. Contact to repairing lab.
7/9/2015 11:36:36 AM • Element... • Answered on Jul 09, 2015
Why am I stuck on one channel
There is only one channel in auto search. Just open searching menu and auto search again your new channels.
7/9/2015 11:29:03 AM • Element... • Answered on Jul 09, 2015
2answers
Tv wont turn on the red light is on but will not
my tv has the same problem. I found if you unplug the TV for a couple of days, then plug it back in, it should work. The tv will also do this whenever there is a power failure or if you unplug the tv to use the outlet for another device.
6/26/2015 11:44:00 PM • Element... • Answered on Jun 26, 2015
3answers
What part do i need to make my tv turn on? It is a model ELCHS321 Element TV with a date of Oct. 2008 on back. I have had it about 2 years and it has worked fine, but it will not turn on now.
It is more than likely a power supply board price may less if it can be repaired a little more if the complete board is replaced. it de pends what state you are in and the servicer .
3/20/2015 1:04:36 PM • Element... • Answered on Mar 20, 2015
When powering on tv the led power button just flashes green
power supply bad caps
2/22/2015 4:33:06 AM • Element... • Answered on Feb 22, 2015
Find my walmart account i ordered a product need info on it
Look at your receipt.
1/3/2015 1:56:25 PM • Element... • Answered on Jan 03, 2015
Fix my color
If you wish to fix your color, just visit any beauty parlour.
12/30/2014 9:02:17 AM • Element... • Answered on Dec 30, 2014
5answers
Element 32" flat screen tv has cracked screen
Sorry, but it's not worth to buy just a screen (probably you cant find just a display), so better start searching replacement tv... Take a lookon amazon or something... Amazon com TV Have a nice day
12/7/2014 8:46:13 PM • Element... • Answered on Dec 07, 2014
Rescan channels
Element ELCHS321 Manuals Check this link to download the user manual to your device. It has all details Electro help
12/7/2014 6:27:45 PM • Element... • Answered on Dec 07, 2014
How to remove off my screen the set parental control pin its blocking the reg. screen?
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/ Unlock procedure and to override the password lock to many popular brand TVs are given.
11/20/2014 10:26:21 AM • Element... • Answered on Nov 20, 2014
How do I fix a flicker in my 32 " element flat screen television model elch s321
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/ In most cases, flicker occur to the fault to its main power supply reguator board.
10/11/2014 9:34:38 AM • Element... • Answered on Oct 11, 2014
Element ELC-HS321 32 in. LCD TV Logo
150 questions posted
Top Element Televison & Video Experts
matt martin
matt martin
Are you an Element Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Element Televison & Video
Most Popular Question
tv 50 element tv flat screen
  • Televison & Video
