I have Simpson top load washing machine eziset 550 5.5kg model no. 36S550L. I haven't use the washing machine after the shoelace stuck down there. I'm not sure if I just cut the shoelace it's going to damage the washing machine after that or not. Or I should get someone to fix it. Anyway, the agitator is still able to spin and there's only 1/4 of the shoelace left under there.
With the bolt out the agitator should just pull up and out. Sometimes they are stuck on the shaft & you have to pull and try to move side to side to get them off. On a few occasions I have struck some that some fool has super glued them on to the shaft. In those cases I have had to break the agitator and install a new one. Just cut the shoe lace. It should be okay.
SOURCE: washer is making a grinding noise. It want spin or agitate.
Coupler between the motor and gearcase is broken...Remove end caps and phillips screws from console. Pull console and flip up..Unplug lid switch and remove gold looking clips on both sides. (push screwdriver strait down and press away from you)..Pull cabinet towards you and remove. Pump is in middle of front by floor..Remove 2 clips with flat head and pull off. ( leave hoses on pump). Remove 2 1/4" screws and remove motor clips with flathead. Motor will fall so hold hand under it. Check plastic and rubber coupler between motor shaft and trans. I guarantee, its broken or worn out..
SOURCE: Simpson EziSet 750 washing machine
the lid-lock button keeps beeping on my simpson eziset 750washing machine. how do i make it stop!
SOURCE: Bad smell in Simpson Eziset 550
pour a few litres of vinegar in the machine on low level of water and do a wash with no clothes in it. should clean tub and drain hose
SOURCE: I have a 3 yr
Hi just read your posting.After the 1st wash cycle the machine drains the water,Is the machine continuous draining?Or does the machine stop the draining and sit there silently?Please reply with additional information and I am sure I can help you.I have worked on this machine alot so if you reply back we can rectify the problem.Looking forward to your reply.
