20 Most Recent
GE GTWN4250DWS 3.9 cu. ft. capacity top load washer Questions & Answers
How do I increase water level?
The water level is controlled by the water level switch. If set to the highest fill level----thats all you get. The government has interfered with manufacturers to try and conserve water so very few of the new machines fill as high as they use to. There use to be a factory set screw on the water level switch for factory adjustments only but if you play with it wrong, you may end up flooding the basement with an over fill problem.
What is causing washer to be very loud and bounce when spinning
When you did not overload it, the only reason I can think of is a bad shock-absorber. When this happens all the time you are washing, it must be that.
Sometimes every thing in the machine clumps together and you have the same effect. If this does not happen all the time, don't worry.
175d2750g308
They should know that info with out asking you if the are truely repair people.
GE WASHER MODEL GFWH1200HOWW RUNNING EXTRAAA LONG ON WASH CYCLES??
Hello Heather
Good to see you again.
Also check the small strainers on the water connectors. They can block up with limescale and debris. While the connectors are off, turn on the water into a bucket or a sink. You should have a VERY powerful jet of water. Anything that will reduce flow will lengthen the fill time and therefore to total wash time due to fill and rinses. When it pumps out, also check you have good flow in the drain hose and items can jam in the ridges and catch lint enough to block them almost completely.
One clever thing to do is whilst the water inlet connectors are off, unlock the drain hose, unhook the part that makes the hook, put the round connector in the hose and wrap a tea towel around it. Get someone to turn the water on full bore whilst you are gripping the two hoses together. Run it for a full minute. Water will be flushed into the machine through the pump in reverse. Put everything back and run a rinse and spin with nothing in it, look at all the black lint that is pumped out! I did that once at work and found an apple stalk that had lodged across the ridges of the drain hose which had 90% blocked the pipe.
Stripped connection at the cold water intake into washing machine
If your inlet valve itself is stripped then you have to replace the valve. The plastic thread is part of the inlet valve. If its only the screen in your inlet valve you can remove the screen and replace it. However if you crossthread anything plastic it HAS to be replaced.
If you give me your model number of the washer usually the wpl 4318046 can be used as an inlet valve which is a cheaper alternative than your local parts distributor would tell you. GE parts on avg are 30% more expensive than anything else. On ANY ge appliance there is usually a way around there replacements with some minor altercations. I wish this site had a way you could contact me directly. I just joined so am not an expert yet but ive done my time in the field. If i could give you any expert advise its DONT BUY GE, OR LG.
Let me know if this helps.
