No it isn't the same. the model number is TB12-2 (670) it was manufactured in 6 of 2001. I talked with Magic Chef who referred me to Maytag and then Maytag referred me to Whirlpool and all of the above cannot figure out who owned the rights to make that model because they have no info on the model number at all. The MPN is CTB122010640149. Thanks if you can help!!!No it isn't the same. the model number is TB12-2 (670) it was manufactured in 6 of 2001. I talked with Magic Chef who referred me to Maytag and then Maytag referred me to Whirlpool and all of the above cannot figure out who owned the rights to make that model because they have no info on the model number at all. The MPN is CTB122010640149. Thanks if you can help!!!
It looks like this is your maker. The controls are pretty simple, bottom heat, top heat, both heat sources. And then a timer switch. With a 16 year old, probably just best to get a new one. I am confident the manual is not available online. http://productspec.ul.com/canada/documen...It looks like this is your maker. The controls are pretty simple, bottom heat, top heat, both heat sources. And then a timer switch. With a 16 year old, probably just best to get a new one. I am confident the manual is not available online.
http://productspec.ul.com/canada/document.php?id=KNUR7.E186885
You can't post conmments that contain an email address.
Step 1
Open the oven door. At the top, left-hand corner of the open oven, locate the model number tag.
Step 2
Check under the burners. Lift each burner on the stove off to see if the plate is underneath. Do this if the plate is not located on the inside of the oven.
Beeping from ovens is an indication of function buttons in user. Observe the entire feature function either as cooker still in operationality where beeping is warning as haven been completely secured from functionality. Refer with an expert with condition over impressive.
