SOURCE: Microwave won't START!!!!!!!!!!!!
It's usually a broken tab on the upper switch holder, allowing the switch to rotate
just out of position.
This tab
can be hard to see, since it is under the bottom edge of the switch.
While replacing the switch holder is the preferred solution, using hot glue to secure the switch to the holder is much easier and quicker. Just be sure not to let the door be slammed from now on.
We have the R1480 service manual for this model and have uploaded it to our site here to help you. You will need the free Adobe Reader to view or print it.
The best place to order Sharp parts is Tritronics.
We're happy to help you and we'd appreciate your
thoughtful rating of our answer.
SOURCE: Microwave key pad stopped working
Okay, thank you for that.
You have a failed membrane keypad, but on this model, it is not available separately.
You would need to order the control panel assembly, part # WB56X10817, which you can get here for far less than GE charges.
It costs more than just a membrane would, but is much simpler to replace.
At
our Web site, we have a video
available showing how to remove a typical
over the range control panel assembly in under 5 minutes.
Then you remove your circuit board from the old frame and install it in the new frame.
We're
happy to help you with free advice and we'd appreciate your
SOURCE: Is there a reset button on the whirlpool microwave JT 358??
hi my name is mark, if the display shows close door then the door switch has failed or is stuck. oven will have to be disassembled to find out. if you do, unplug unit first, before removing cover. thanks for your question.
SOURCE: It starts heating when the door is closed in certain position
See:
http://www.microwavedisplay.com/safety.txt
http://www.microwavedisplay.com/disassembly.txt
http://www.microwavedisplay.com/doorsw.txt
We're
SOURCE: Panasonic NNH965BF microwave starts but immediately shuts off
your mag has gone bad and possible that the inverter board as well, not really worth the hassel
