20 Most Recent KitchenAid Microwave Convection Oven Questions & Answers
I own a KitchenAid KEHC309JSS05 and the microwave
common problem with lots of MWs - the door switches are not set and secured properly. Now they are totally off. Need to pull apart and reset. Not a task for an average homeowner. Mine (Whirlpool) did that 1 week after I got it - exchanged for a new one.
8/7/2019 6:42:06 PM • KitchenAid... • Answered on Aug 07, 2019
Code F6, E0, "Communication Error"
Hi. this code represents a key pad or control board malfunction. you will have to make sure the key pad or control panel connectors are connected tightly and securely. If the wires and connectors are secure, the actual control board may be faulty and you will need to replace it at this point.
8/7/2019 6:13:11 PM • KitchenAid... • Answered on Aug 07, 2019
Where can i get a
8/7/2019 5:28:18 PM • KitchenAid... • Answered on Aug 07, 2019
Describe your 30 in. Built-in
The door switches are the problem. Well, actually one of them is. when you open and close the door make sure the switches are actually being engaged. I have seen the plastic snaps that hold them broken and the switch just moves. Just replace all three switches and you will be fine.
10/29/2017 6:15:50 PM • KitchenAid... • Answered on Oct 29, 2017
Kitchen aid kemms308sss04 plastic insert on turn table broke how do you replaace
That may be called the turntable coupler or turntable support or roller ring assembly.You can find helpful exploded views and part numbers at the link below, by replacing XXX with the full model number found on the tag on your microwave (not on the service manual). XXX&siteCd=WHRCOM&userType=Consumer">http://shared.whirlpoolcorp.com/product_literature/search_results.jsp?searchTerm=XXX&siteCd=WHRCOM&userType=ConsumerMy preferred place to order Whirlpool parts is from the Pro here.
2/17/2014 10:20:14 AM • KitchenAid... • Answered on Feb 17, 2014
0answers
F6 e0 code
Be the first to answer 1/30/2014 11:31:15 AM • KitchenAid... • Posted on Jan 30, 2014Be the first to answer
0answers
Manual for flavel FLS63FX
8/4/2012 1:25:41 PM • KitchenAid... • Answered on Aug 04, 2012
0answers
KEHC309JSS05
Be the first to answer 1/3/2012 5:22:04 AM • KitchenAid... • Posted on Jan 03, 2012Be the first to answer
Problem with the KitchenAid 30
well i will give you a link to suggestions that have already been made by other experts on Fixya. click here
otherwise,
A. Unplug oven or disconnect power.
B. Open the back panels and make sure the P6 and P2 connectors are fully
inserted on the appliance manager and on the lower oven user interface board.
- If they are not plugged in, plug in connectors and go to step F.
- If they are plugged in, go to step C.
C. Visually inspect all wires between P6 on the appliance manager and P2 on the
lower user interface.
- Make sure wires are not cut or pinched.
- If the wires appear to be intact, perform a continuity check between
P6-1 of the appliance manager and P2-1 of the user interface board.
3/9/2011 2:08:57 PM • KitchenAid... • Answered on Mar 09, 2011
Hi there, unit worked fine this morning heating
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic Microwave Oven Troubleshooting Tips
heatman101
2/25/2011 3:34:28 PM • KitchenAid... • Answered on Feb 25, 2011
How to replace torsion spring
If this is the flip down door. You will need to take apart the side cover of the unit to fasten the spring. Once you have done that you need to put a pen or something to hook it so it doesn't drop down in the unit. If you are unable to hook the spring in the door. You must take the outer cover off the door to hook the spring and then replace the cover. You may find this to be a two person job and may be easier to hook the door before you hook the unit. Some doors are different then others.
2/8/2011 12:48:54 PM • KitchenAid... • Answered on Feb 08, 2011
The microwave seems like its
chk the door switch also chk the input supply to the control board and smoothing capacitors
2/6/2011 7:28:48 AM • KitchenAid... • Answered on Feb 06, 2011
I bought this microwave and
May I get the make and model # to help you more
1/23/2011 4:33:07 AM • KitchenAid... • Answered on Jan 23, 2011
We have a KitchenAid built
I cannot determine from your description what part it is you exactly need.
This is a link to Sears Parts and you make and model
Look through the diagrams.
As for price and delivery... that's up to Sears
http://www.searspartsdirect.com/partsdirect/part-model/Kitchenaid-Parts/Microwave-Parts/Model-YKHMS1850SS0/0593/0123370?searchedModel=YKHMS1850SS&blt=
1/2/2011 1:27:50 AM • KitchenAid... • Answered on Jan 02, 2011
KitchenAid Microwave Convection Oven Logo
43 questions posted
Top KitchenAid Microwave Ovens Experts
ZJ Limited
ZJ Limited
john h
Are you a KitchenAid Microwave Oven Expert? Answer questions, earn points and help others
View Most Popular
  • KitchenAid Microwave Ovens
Most Popular Question
when open door hold from
  • Microwave Ovens
