U0073
Control Module Communication Bus Off
Digital Signal Processor
REFER to Section 418-00 .
U0073
Control Module Communication Bus A Off
EATC Module
U0073
SJB
U0073
TCM (FNR5 Speed Transaxle)
REFER to the Powertrain Control/Emissions Diagnosis (PC/ED) manual.
U0073
TCM (6 Speed Transaxle)
Your best bet , take it to a qualified repair shop . You do not have the knowledge or diagnostic test equipment to diagnose this . Do you know what C.A.N. - controller area network is ?
Communications Network
Vehicle communication utilizes both medium and high speed controller area network (CAN) communications. CAN is used for many modules to communicate with each other on a common network. CAN in-vehicle networking is a method for transferring data among distributed electronic modules via a serial data bus. Without serial networking, intermodule communication requires dedicated, point to point wiring resulting in bulky, expensive, complex, and difficult to install wiring harnesses. Applying a serial data network reduces the number of wires combining the signals on a single network. Information is sent to the individual control modules that control each function.
The vehicle has 2 module communication networks:
Both networks are connected to the data link connector (DLC). This makes diagnosis and testing of these systems easier by allowing one scan tool to be able to diagnose and control any module on both networks from one connector. The DLC can be found under the instrument panel between the steering column and the audio unit.
016 CAN Communications
P0020 - Intake Camshaft Position Actuator Circuit/Open (Bank 2)
Description:
See the description for DTC P0010.
Possible Causes:
See the possible causes for DTC P0010.
Diagnostic Aids:
See the diagnostic aids for DTC P0010.
Application
Key On Engine Off
Key On Engine Running
Continuous Memory
All
GO to Pinpoint Test HK .
SOURCE: u0073 u0101
0073 ambient air temperature sensor circuit high input 0101 mass or volume air flow circuit range performance problem it sounds like the mass air flow sensor is dirty check with your G.M. dealer to see if its still in warranty
SOURCE: ENGINE CODES
Whenever engine fault codes set, VSC is disabled and lights come on. P0020 shows failing cam shaft position sensor , recommend replace clear codes and recheck. gas spill was coincidental.
