SOURCE: Recognizing / Reading SD Card?
Yes...go to the google website or drivers.com to find the driver of your computer and you can type the search box "dowload" your specific brand of you pc..............
SOURCE: Cant read SD card.
first, try to take the "micro" card out of the main body and re-insert. the internal contacts may just be a little bit dirty. (you may want to also GENTLY buff the internal AND external contacts with a SOFT {cotton} emery type of fingernail board or Q-tip with a SMALL amount of rubbing alcohol. {let it get dry before you re-assemble}). try that and see if it works for you.
SOURCE: Kingston 4gb sd card won't read
I had a problem with lenovo's reader like this, because i put in the nokia 6600 card, correct format and all, but apparently too old and not yet ment to be read by a computer ...
sd could still be hc ... the system of names is still not set up right. if you got a small black attachment for the card that makes it longer, put it on and try inserting the card again.
check if all the drivers are like they should be.
if you've got a friend with a card reader, make sure the card is ok. and if you've got a friend with a card, make sure the reader is like it's supposed to be
post a feedback, ok
SOURCE: my acer can read an sd card,How can I get it to
While the spec sheet does not say SDHC specifically I am surprised it does not read and write it since it is an up to date unit but if it wont you can get an inexpensive USB 2.0 reader and it will work. I would check and make sure that the SDHC card is formatted properly if it is go with the adaptor. Good Luck
