Washing Machines Logo
Ian Heskins Posted on Nov 04, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Can not open the door Ariston, 8.5kg, - Washing Machines
NOEL
Level 3:
Top Expert:
  • Washing Mach... Master 8,606 Answers
  • Posted on Nov 04, 2017
NOEL
Level 3:
Top Expert:
Answers
8606
Questions
18
Helped
2322498
Points
68630
HI THERE.
THIS IS ALL I COULD FIND ABOUT HOW TO OPEN A DOOR THAT IS STUCK.
how to open washing machine door that is stuck Google Search .
go to this link and have a look and see if it helps you out.
Door locked,cant open
just get an old door from any ariston..hotpoint or indersit machine make sure it is the same size
1helpful
Cannot open Wash door
Here is a tip that I wrote about how to get your washing machine door opened...
Washing Machine Door Jammed
heatman101
Door handle on ariston awd12s has broken how i can i get the door open
open the table top of the machine and release the door switch by any flat screw driver
1helpful
How to unlock the hinge on an Ariston Oven Door with door off
To Unlock the hinge on an Ariston Oven Door
Lay the oven door flat on the worktop with the inner door upwards and the locked hinge facing you.
With a pair of pliers and a good grip on the hinge, force the locked hinge towards you (by pulling it open towards you) and keep it in position by flipping the U piece over.
Fitting the Oven Door
Fit the door to the oven with the metal receivers in the slots on the oven.
Once the receivers are in the slot, fully open the door (in a downward position).
Flip the U shaped pieces over to lock the hinges.
May 17, 2010 • Ovens
Ariston LI 45 door will not remain closed and will
Strip the door and re-set the switch. Ensure the metal part of the catch on the machines main body is not distorted
2helpful
2answers
Cant open door of washing machine
I plugged it out. Left it for 15 minutes. When I went back the door could be opened and it also started to wash.
3helpful
2answers
Door Stuck after wash completed
You will have remove top cover, and release door latch from inside the front, with a screw driver pushing against the latch to open door.
It does mean that you probably have a faulty door lock, or broken door handle.
Please rate my fixya solution.
Thanks
1helpful
Ariston AWD 120 Door Handle is Loose
unplug it.
open the top lid.
reach down inside and feel a plastic sensor/release behind where the latch is.
towards the left center of that sensor, feel for a metallic manual release (you'll just feel the nub of it).
Push this in and to the side to manually release the door lock.
Call Ariston and complain about this common problem.
1helpful
Door wont open
Try first to unplug the power cable. In case it will not help,you have to raise the top of the washer to get to the switch (near the door)and try to open it manually. If the problem will return,you should replace the switch. Good luck!
Top Washing Machines Experts
john h
