Health & Beauty Logo
R
Ralph Pantoja Posted on Oct 31, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Where do you activate the Scale MIN function for the ENCs?
medypharma2148
Level 2:
Sergeant:
New Friend:
  • The Expert 176 Answers
  • Posted on Feb 18, 2019
medypharma2148
The Expert
Level 2:
Sergeant:
New Friend:
Answers
176
Questions
0
Helped
103903
Points
707
Buy Tasigna 200mg Online Nilotinib is a prescription oncology ****. Tasigna 200mg manufactured by Novartis Pharma Ltd. Know more about Tasigna 200 mg price in india, Norvatis, manufacturer, cost, dosing, side effects. Order Now.
Gao Mink
Level 2:
Sergeant:
  • The Expert 66 Answers
  • Posted on Mar 18, 2018
Gao Mink
The Expert
Level 2:
Sergeant:
Answers
66
Questions
Helped
12827
Points
973
Where do you switch between Paper Chart Symbols and Simplified Symbols in the ENCs?
ENCs, or Electronic Navigational Charts, are digital versions of paper nautical charts that are used for navigation. In ENCs, different symbols are used to represent features such as buoys, obstructions, and shorelines.
The switch between paper chart symbols and simplified symbols in ENCs can typically be found in the settings or display options of the software or app that is being used to view the charts.
For example, in ECDIS (Electronic Chart Display and Information System), the settings for symbol display can be found in the "Chart Display" or "Chart Display Options" menu, and there may be a setting to switch between "Standard" or "Simplified" symbols.
Similarly in other ENC software like ENC viewer, it can be found in the settings or display options and have the option to turn on/off the Simplified or Detailed Symbol display.
It's important to note that the availability of this option may depend on the specific software or app that you are using, and you may also want to check the user manual or documentation of the software for specific instructions on how to switch between different symbol sets.
Where do you activate the indication of chart data Accuracy (CATZOC) in the ENCs?
https://www.myseatime.com/blog/detail/zone-of-confidence-and-catzoc
Saeco Vienna deluxe is slow functioning post power on. 3 to 5 min. for the middle green light remain on. Press brew switch takes a 2-3 min. for the pump 2 activate. Once activated, coffee flows fine.
Machine is screaming for descaling. The Calcium deposits in the system are slowing down heating.
Do not think of using Vinegar.
Do not use R.O water or consider water is very soft in your area. There is nothing like that.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edward_bbd2c7ff4ee1828a
4helpful
I would like to change my ThermoScan from Celsius to Fahrenheit but I am not sure what buttons to push to achieve this
Changing the temperature scale from F to C: - - Turn on the thermometer - If the unit is already on, make sure it is not in the memory mode - Press the ?/MEM button and keep it pressed. Then press and release the activation button to switch over to the "change temperature scale" mode. - By pressing the activation button again, the opposite scale will be activated. Each further pressing of the activation button rotates the measuring scale
How do I change my Braun ear thermometer back to F from C
You did not provide a model number however the Instruction Manuals for the various Braun Thermometers can be found here:
http://braun.kaz.com/kaz/service/prodResult/
Not sure if this procedure is common to all but this may work otherwise find the manual specific to your model number.
This thermometer is shipped with the Celsius temperature scale activated. If you wish to switch to Fahrenheit ( °F), proceed as follows:
Turn on the thermometer. ( If it is already turned on, make sure it is not in memory mode.)
Press the /mem button and keep it pressed. Then press and release the activation button to switch over to the «change temperature scale» mode.
By pressing the activation button again, the Fahrenheit scale is activated, «°F» is displayed on the LCD. Each further pressing of the activation button toggles the scale between °C and °F.
Release the /mem button to return to the ready symbol . The temperature stored in memory will automatically be converted to the selected scale when displayed on the LCD.
3helpful
How do I choose the dimensions for the graphing window?
There should be a WINDOW button or key when looking at the graph. Hit that button and the screen should show the x min, x max, x scale, etc. From here you can change the x-min and x-max to whatever you would like. Same is true for the y values. Default is -10 for x and y min and 10 for x and y max with both having a scale of 1.
3helpful
Have a braun thermoscan and want to change it from F to C degrees lost manual
From the manual of the thermometer:
This thermometer is shipped with the Fahrenheit temperature scale activated. If you wish to switch to Celsius (°C), proceed as follows:
• Turn on the thermometer. (If it is already turned on, make sure it is not in memory mode.)
• Press the /mem button and keep it pressed. Then press and release the activation button to switch over to the «change temperature scale» mode.
• By pressing the activation button again, the Celsius scale is activated, «°C» is displayed on the LCD. Each further pressing of the activation button toggles the scale between °C and °F.
If this isn't the right manual, go to: http://braun.kaz.com/kaz/service and select your country from there.
1helpful
3answers
How to set the window?
Press [Window]
Set the values of Xmin, Xmax, Ymin, Ymax.
If the x values that the function takes are all positive, you may set Xmin =0. If the values of the function are all positive, you can set Ymin=0.
If you are drawing a sine or a cosine function, you know that the function values are between -1 and +1, so you cant restict Ymin an Ymax to say -1.2 and 1.2. Similarly if you draw trigonometric function no need to have a range of X values between -10 and 10: the function being periodic you can restrict values (in radians to -pi to +pi, ) or to -90 to +90 degrees.
You set the limits of the window by making use of your knowledge of the functions you are drawing.
Hope it helps.
Top The Health & Beauty Experts
Paul Carew
Steve Sweetleaf
Steve Sweetleaf
Are you a The Health and Beauty Expert? Answer questions, earn points and help others
