I already changed new batteries but the problem remain same . After charging the vacuum just run couple of minutes then turn off
Normally the battery gives up in this vacuum cleaners through my experience
confirm the charger first
use a voltage tester to check the voltage coming from the charger
the voltage will read from 12volts to 18 volts
depending you vacuum model.
If you the voltage is present then the battery is dead.
SOURCE: My Electrolux pronto is slow to start, if it
I just wanted Electrolux to know that this is the Pronto 2-1 is the worst product I ever purchased. I thought after I received the new battery because of the recall it would work.
When I was going to purchase the stick broom I was going to get the Shark but because I knewElectrolux was a good name in products I decided to purchase the Electrolux which I truly regret because it was just a waste of money
this sounds totally silly but is the power button on the vacuum actually off? Had the same problem, where the battery was completely empty i didn't know my son had switched the vacuum on put it on charge and the light was flashing. I took it off the charging stand pressed the power button then put it back....now charging perfectly. Anyone who doesnt have this appliance will think you sound stupid but its just a clicky button so visually the button looks the same on or off.
