Televison & Video Logo
Anonymous Posted on Jul 28, 2009
I had to unplug my cable/tv last night and when I turned it on this morning I could not get the menu to display the cable accept on the menu screen. I went in to turn off the home theater and the cable comes right up but cannot get it to come on tv screen after going out of menu. All I get is Ant A or B blue screen. Can you help me get my cable on the tv screen? Mitsubishi vs50604 tv...
Anonymous
Level 1:
Problem Solver:
  • Contributor 1 Answer
  • Posted on Jul 29, 2009
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
Questions
7
Helped
88
Points
Push the menu button and enter 1370 and push enter and the tv picture will appear on the screen. If it does not push the input button until the picture appears.
3answers
Sony KV32XBR400 Video Won't Turn
1. Try this - hold the menu button down for 10 seconds. TV should power up; you will have to turn off front panel buttons on menu.
2. You can also try a hard reset: Unplug TV from AC mains and remove all cables from TV. Wait about 30 minutes and replug to AC power and redo the cabling. Switch on the TV and see if it works..
I turned off the tv last night like every night but this morning there was sound but know picture. I checked all the cords/cables I unplugged and plugged them in but nothing. I cant even get the menu to...
What is the make and model of your tv? If this is an lcd or plasma, is there a backlight that comes on when you press the power button? If this is a dlp tv, do you see the lamp light from the back of the set? If you give me make and model I can download service manual to give you more informed information.
Just bought a ps3 two weeks ago. Played games just fine and everything worked well. We watched a movie last night. Turned off the system and went to bed. The next morning we tried turning it on but it...
This may be a simple fix. Do you still have the original cable that came with it for the video OUT? Plug this back into your playstation and TV while leaving the HDMI cable connected.
check now both HDMI channels and AV/Composite options on your source selection this should give you the display,
Now what we need to do is setup your HDMI output again.
From the menu bar,
  • Go to settings
  • Display Settings
  • Video output settings
  • choose HDMI
if you have the choice to choose OK choose it. If your screen goes blank go through your HDMI channels again and if the Playstation screen is there then select OK,
Then you can remove the composite cable again
2answers
Last night the tv was fine i turned it on this
Unplug 20 minutes. Make sure there is adequate ventilation around the set.
Try with the original manufacturer remote to view setup menu.
Power outages come at night. This sometimes resets the TV and other devices. .
Maganavox flat screen tv no pic, red light blink codes...
Those blinks are fault codes. To know more visit the site linked here. http://electronicshelponline.blogspot.com/
1helpful
I have a Sharp Aquos TV that only displays a colorful grid.
your t-con board is failing call a tech to install a new one
KP-43t75 no picture black screen, Menu comes up bowed
Ur convergence it dead.Buy a convergence kit,replaced what in that kit.Know how to solders right?Buy a convergence kit in these websites Tv repair World.com,Tv rpair Kits.
No picture but sound works.....
  • adjust brightness setting when playing tv.
  • adjust screen control located on flyback transformer.
  • hope this will help.
1helpful
RCA 32V420T 32" TV
reset by unplugging AC cord for few minutes, a few hours,or overnight,if needed.Let me know if that does not work.T.
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
