Https://www.youtube.com/watch?v=KFbfjNH19E8
is this a video you have seen
Yes, that's the video that prompted me to purchase a filter and change it on my own. Looked so simple to access. Another one showed a guy way back, under the dash on passenger side, removed a couple of screws to easily access filter from down there, but that did not look the way my 2007 SX4 looks either. Any suggestions? Will try to add photo soon. Thanks!
I just changed on my Chrysler 200 I think similar. I open glove box press in on sides of glove box back near dash(I moved glove box about a 1/4" back in and pushed sides). It came out a little more there is a rubber cord attached on the right side where it attached to glove box slid it forward and it came loose from glove box. the glove box door went to the floor and I just pulled it down and glove box door was off. No tools needed for mine. I could then change the filter. Installed door by putting near floor and pushing up.
SOURCE: Cabin air filters
The two filters are located behind your glove compartment, you have to remove the glove box and you'll find them.
SOURCE: I need to replace cabin air filter for my 2003 freelander
There are 4 screws holding this in place and it takes a torx bit no.T20
SOURCE: Cabin air filter location 2003 F250 6.0L crew cab pickup
hey jack open the back door and look up top where the hinges are and that should be the one for the back and the front if it is not up under the hood where the wipers are then check up under the dash
SOURCE: How to I replace the cabin air filter in my 2008 MC C300
Remove the three torx screws using a torx-20 screwdriver...pull back the padding in the footwell...there is tab holding the left part of the plastic piece, use a flat-head screwdriver
to pop it out...you may need to disconnect the light connector, and the cigarette lighter connection.. Once the plastic piece is out, you will see a large white box, the filter is
inside this box. There are two yellow clips that need to be slided to the
left/right. The box then pops out from below and the folded-filter will fall
right out
Good luck..i hope this helps..please rate me a fixya.
SOURCE: MB 2008 C300 cabin air filter where
under hood,over battery, when facing windsheild top left by firewall
