Hey Pete.. this sounds serious.... will it rev up while in neutral? If it revs freely and high.. the power head should be ok.. if it will NOT rev up freely and high.. STOP - you are causing more damage..
Check the compression with a good gauge..it should be 125psi minimum.. with no more than 10 psi difference between any two cylinders.. DO this WITH the THROTTLE WIDE OPEN...
Can you turn the propeller by hand while it is in neutral?..Of not.. this is the problem.
Shop Evinrude Outboard Parts Johnson Outboard Parts
Lower Unit Replacement Rebuilt Lower Units Aftermarket Lower Units
REMANUFACTURED LOWER UNITS
https://www.boatengine.com/lower-units/remanufacture
Refurbished Lower Units for Yamaha Mercury OMC Johnson Evinrude
