SOURCE: PS3 (Pal) won't connect to Sylvania HD TV
I just figured it out last night - if you have used your playstation on an hd tv previously, it is set at the highest resolution possible - 1080p. You need to take it back to that tv, and go to display settings on your tv. If you select HDMI as they type of connection you'd like to make, it asks you what resolution your tv supports. In your tv instruction guide, it should give you this information. Check mark all of the resolutions your tv supports, making sure not to confuse 1080i and 1080p. After doing this you can take it back to your other television and it should work.
SOURCE: Sylvania LC320SS9 HD LCD TV Closed Captioning not working
Well first you can view your TV's manual at
http://www.sylvaniaconsumerelectronics.com/pdf/om/LC320SS9.pdf
Go to page 24 through 27.
IF that does not help you, comment me back.
Thank you for using Fix Ya!
Don't forget to rate the overall satisfaction of this solution.
SOURCE: Need remote code for Sylvania 32" LC320SS9 for Dish controller
Please follow the steps below to program your remote control to equipment other then your DISH receiver:
Note: If you start this procedure and at any time and do not press a button within 20 seconds, the remote will end the procedure automatically. Simply start over again. Use the TV button for your TV, the VCR button for your VCR or DVD player. These Mode buttons are located at the top of your remote control.
1. With the desired equipment on, press and hold the correct Mode button until all mode button backlights illuminate, then release.
2. Press the numbers 5-0-0 on the remote control.
3. Press the Pound (#) button on the remote.
4. Press and hold the correct Mode button until all mode button backlights illuminate, then release.
5. Press and release the Power button on the remote control.
6. Press the Up button once a second while pointing the remote at the desired equipment. If the code for the equipment comes up, the equipment will power off.
7. Press the Pound (#) button. If the code entered is valid for the remote, the mode light flashes three times.
8. To verify the code works try several different functions for that equipment.
We cannot guarantee our remotes will work all other devices. If this does not correct the issue, unfortunately our remote will not work for that device. We apologize for any inconvenience this may cause.
Let me know how it goes and please rate this solution
Lone99star
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/jason_77a19afa8d604dee
SOURCE: 32" Sylvania TV/DVD won't work with my AT&T UVerse Remote
I bought a 32 inch sylvania LD320SSX TV/DVD and had trouble with a Media-Com remote. Finally got it to work using code 1864
Good Luck
SOURCE: My LC320SLX Sylvania TV displays the message
You are getting that message becuase the MAC video resolution is too high for the TV handle, you need to lower your MAC video resolution to the native resolution of the TV, read your manual to find out what it is.
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
