Jonathan Hanas Posted on Mar 15, 2017
Gpx D505 manual
How do I set the time?
D505 user manual
You may use the below link to find the Dell Latitude D505 Service manual:
http://dell.to/1zfD3ua
Thanks and Regards.
Kiran Kumar.
#iworkfordell.
How do i make my mp3 mw353 shuffle
"Menu Press to access the menu and make selections. Use the Skip/Search buttons to navigate the menu. In Play mode, press to set the EQ or repeat settings. In Pause mode, press to access the local folder and delete options."
Ok this operation is the same with my ml961. I found this in the pdf download for your unit. Hole the menu button for a few sec 3-5 release you will be in a menu to set various features for music.
This should be in the manual that came with you unit. I had to go through mine a few times to find it Then I was looking in the wrong spots of the manual. I know a lot of us figure we can figure it out right off that bat but unfortunately GPX did not make that easy. here is the link to download the manual it is only in pdf 4GB Digital Audio Player MW353B GPX
Hope this is of help.
1helpful
We dont have a manual and we dont know how to change the channel or set the time
To set the clock on the unit, have the TV connected to power but not on. Then press and hold Mem/Clck Adj on the TV (it's the third button from the right in the top row of controls). Use the adjacent Tune/Clk (up/down arrows) to set the clock for 12 or 24 hour time. Then press Mem/Clk Adj again to adjust the hour with the up/down arrows. Press Mem/Clk Adj again and set the minutes. Press Mem/Clk Adj to save the time. The original remote also has these buttons. Mem/Clk Adj is also labeled Set and is the furthest right button on the second to bottom row of the remote. The Tune/Clk buttons are the DN and UP buttons on the left of this row.
Use the Tune/Clk arrows to change the radio channels after pressing the radio button (second from the right on the bottom row). When you press the TV button (first on the right of the bottom row) to watch TV, then you need to use the Channel up/down arrows at the top and bottom of the ring control on the far right of the TV or the Channel + and Channel - buttons on the remote. On the remote, the Channel + button is below the timer button which is below 9 in the keypad section. Enter is below the Channel + button and Channel - is below Enter. Make sure that the TV is in the correct mode for your signal (ATSC for OTA and NTSC for analog cable) by pressing the TV mode button. If you are using a set top box, you will need to change the channels at the box.
Press the TV Menu button and then go down the list to Time to set the time zone for the TV. Press Enter to save the setting. Use the TV Scan button to get a list of available channels before trying to change channels.
The manual for the GPX KL868S is available from GPX at the product page: http://www.gpx.com/store/p/287-KL858S.aspx . The direct link to the English version of the manual is: http://www.gpx.com/owners_manuals/KL858S-IB.pdf .
I hope this helps.
I have a gpx hm3817dtblk shelf system and i was wondering if you can get the alarm to play a cd instead of the radio or if you can do either one and how? Or does it even have an alarm?
The manual:
http://www.retrevo.com/support/GPX-HM3817DT-manual/id/1183ag710/t/2/
Page 6>>>>
Setting the Clock
a. Press the STANDBY button until the unit is in standby mode.
When the unit is in standby mode, the STANDBY button will be red.
b. Press the CLK ADJ. button. The time will begin to blink.
c. Press the HOUR and MINUTE buttons to adjust the hour and minute.
d. Press the CLK ADJ. button to set the adjusted time.
Setting the Alarm
b. Press the ALARM SET button. The time will begin to blink.
c. Press the FUNCTION button to seleect CD, Radio, AUX, or Buzzer.
For Buzzer mode, the display will not show any indication.
d. Press the HOUR and MINUTE buttons to adjust the hour and minute.
e. Press the ALARM SET button to set the adjusted alarm time.
An alarm clock icon will appear on the LCD Display when the alarm is set.
1helpful
Can't set clock and alarm. No manual.
You can get the manual at this link--you have to join but it's free and a very usefull site for finding manuals:
http://www.retrevo.com/s/GPX-HM3817DT-review-manual/id/1183ag710/t/1-2/
IF THIS SOLVES YOUR PROBLEM, PLEASE PLEASE RATE ME AS "FIXYA"!! THANKS!
2answers
GPX clock radio clock question
I emailed the company and they sent a pdf of the manual back the same day.
[email protected]
Top GPX Audio Players & Recorders Experts
SmartAviator
SmartAviator
 Grubhead
Grubhead
Are you a GPX Audio Player and Recorder Expert? Answer questions, earn points and help others
