It's a newly bought less than one month, I pulled up the lever al the way up, because the water comes out once the lever reaches its half way. I did a research in Youtube, but none of the videos could solve the problem. I also tried the bleeding, again it doesn't solve the problem.
Try running some white vinegar through it as if you was making coffee (but don't use any coffee) and when done either repeat processes or run a clean pot of water to clean out the vinegar and see if the water is coming out faster. You might need to repeat process a few times. The vinegar breaks down any hard water residue.
Testimonial: "Thank you for helping me. Actually, it's the lever problem. Soon later, the water will come out very slow even if I pull the lever all the way up."
