20 Most Recent
La Pavoni Lusso PL-16 Espresso Machine Questions & Answers
Hi can you tell me how to reset the safety
Hi Rob,
Open the top of the machine. On the heater element you'll see 8 cable connection: 2 on one end, 3 pairs on the other. The safety reset thermostat is on the middle of the 3 pairs (easy to spot the other 2 is flat, the middle one has a 2mm part sticking out). Remove that pair of cables - just in case - and push that button in. You'll hear a clicking noise. Connect the two cables back to the element and follow the "starting up procedure" from your manual. If you did everything correctly the machine will start to operate. Turn it off and put back the top. That should be it.
Our La Pavoni Lusso machine has not been used for
Try opening the steam nozzle while trying to pump the water through as this will get rid of any air locks. Otherwise it may be a build up of scale in the boiler or the pump itself. Try that and descale if you can.
All the best
LaPavoniBoy
La pavoni slow water flow
Try running some white vinegar through it as if you was making coffee (but don't use any coffee) and when done either repeat processes or run a clean pot of water to clean out the vinegar and see if the water is coming out faster. You might need to repeat process a few times. The vinegar breaks down any hard water residue.
