SOURCE: installing a new kyocera TASKalfa 250ci and i got
C3100 Scanner carriage problem
• The home position is not correct when the power is turned on or copying the document placed on the contact glass.
Poor contact of the connector terminals.
Defective scanner home position switch.
Defective engine PCB.
Defective scanner motor.
This copier may need a service adjustment. The problem could be something as simple as a switch not being in home position. Please troubleshoot accordingly. Unplug device when troubleshooting.You should also troubleshoot it by looking to see if anything is blocking or stuck causing the carriage to not go into position.
SOURCE: kyocera FS-1016MFP "printer error service
Code: 6000
Contents: Broken heater lamp error
The temperature won't rise by 1°C/33.8
°F during warming up and the heater is
turned on for 5 seconds.
°F during printing and the heater is
turned on for 5 seconds with the duty
cycle more than 60%.
Causes:
- Defective fuser thermistor.
- Broken thermal cutout or heater lamp.
- Defective engine/high voltage PWB.
SOURCE: my kyocera taskalfa 180 showing
C6400 is a fixing unit error.
To reset -
Try this, enter "10871087" from keypad, You should now be in maintenance mode.
Enter "163"press "Start / Print" key.
You should see a screen that says "Execute".
Cursor / highlight "Execute".
Press "Start / Print key.
The machine will turn off and should come back to ready. If not then you need to replace the fixing unit.
I hope this is helpful,
Shawn
SOURCE: Free service manual with code
To reset -
C-TECH INFOWAYS
