Watches Logo
D
Doug Mills Posted on Dec 27, 2016
How do I set the day on my T2M935 Timex Watch?
How to set time day date on my timex indiglo cr2016 watch
To set the time and date on your Timex Indiglo watch with a CR2016 battery, follow these steps:
  1. Press and hold the stem (the button on the side of the watch) until the display begins to flash.
  2. Use the stem to cycle through the different settings: time, day, date, and year.
  3. When you reach the setting you want to change, use the stem to adjust the value.
  4. Once you have set the time, day, date, and year to the correct values, press the stem to exit the setting mode.
If you have trouble setting the time and date on your watch, you may want to consult the manual that came with the watch for more detailed instructions. If you do not have the manual, you may be able to find a copy online or you can try contacting Timex customer service for assistance.
How can I change the day on the watch (timex model T2E581). I am able to change the date and time ok, but not the day. Thanks for the help.
When you pull the stem out all the way (two clicks) it should set the time. Pulling the stem out one click you noticed sets the date, you turn it one way for the date and in the same postion you turn it the other way for the day. For some reason on some watches the day will stick, if that still happens you will need to turn the hands around and around until you get to the right day, then keeping in mind the 12 hour interval you are in... set the date and time. If the day still does not change then you need to return the watch if its new or send it to timex! Caution: when sending a watch to Timex sometimes they send back a different watch without asking so if its sentimental do NOT send it to Timex!! Hope this helps! have a great day!
2helpful
How to set the day on the timex, as i am able to set the date but i dont know how to set the day of the week in T46601-V1 model watch
it can only set by turning the time for 24 hour using the crown the day of the week changes every 3 AM, i hope i had helped you.
1helpful
2answers
My timex watch changes the date at noon instead of midnight. How do I fix this?
This is because you have reversed am with pm.
Set your watch 12 hours back and the problem should be solved.
You might want to wait till midnight or noon to check it's fine.
Note: if you see the day shows the previous day rather than the present day, you have to set the clock 24h ahead.
Problem solved!
1helpful
Date and time on my new watch do not change
mcdevito75 here, Sounds like part of the mechanism has broken in your Timex watch, and, if so too repair it may cost twice a new Timex watch, chances are this is why watch shops have told you to return the watch to Timex, and without a warrantee, even timex will charge for the repair. Ask the watch repair shop straight out if it pays to repair your watch, chances are no. Also you can try to contact Timex online at Timex watch.com or by phone.
Timex Women's T5K188 Digital Ironman Pulse
You can get instructions from the Timex web site "timex.com".
At the bottom of the screen click on "manuals/downloads", then on "product
manual download"
Enter your watch type in the search box and click on "search"
4helpful
I have a Timex indiglo wr 30m wrist watch and I can't set the day
http://www.timex.com/info/Product_Instruction_Guides_Downloads
Use the numbers on the back of your watch and you will have a PDF version of your instruction manual.
Hope this tip helps
R/
David
3helpful
Alarm set
You may find a solution here:
http://assets.timex.com/manuals/?timexBrand=core
Rate me, please.
Outdoor Timex Expedition watch
Dear sir,
i bougt a watch timex expedition indiglo wr 50m from ansal plaza in shopper stop in this watch i find some nylon type of thred in this watch when i gone on there he is saying that leave it for 7 days i bougt from there on aprox 20 days before plz suggest me waht have to do
my contect no 9818190399
my mail id is [email protected]
and [email protected]
Top Timex Watches Experts
Paul Bade
NOEL
NOEL
Ngoro
Are you a Timex Watch Expert? Answer questions, earn points and help others
