20 Most Recent Timex Expedition 40141 Wristwatch Questions & Answers
Remove the battery and check the contacts at the bottom of the cavity to be sure they haven't gotten mashed flat. The cell should seat firmly in the cavity, not just rest in it. Be sure the back is seated firmly.
Timex Expedition... | Answered on Feb 19, 2018
There is no separate battery for the indiglo,maybe indiglo circuit is lose or defected already,just open the watch and check for lose connection.If happen the circuit is tight and still not working then replace the indiglo circuit.
Hope it may helps you;
Regards
VOTIT
Timex Expedition... | Answered on Apr 23, 2017
Replace the back cover with the arrow pointing directly at the stem. Everything should work correctly with the cover in that position.
Timex Expedition... | Answered on Feb 18, 2015
To clarify... Replace the cover with the arrow on the back pointing directly at the stem. The Indiglo backlight, alarms and chimes should all work when the back cover is in this position.
Timex Expedition... | Answered on Nov 08, 2013
I have a Timex Expedition Indigo with a metal case. Not sure of the exact model number but on the back there an M6 below Expedition. Anyway, I had the same problem of snapping the back back on. I found a "battery" website that had some suggestions that should be typical of any snap back case watch. http://www.online-batteries.co.uk/whichbattery.shtml specifically they said that when you try to press the back on it must be flat (not one edge down as I had been trying) Put the watch face down on a non scratch surface and press with both thumbs evenly. If that doesn't work a press will be needed. If you have a vice a couple of blocks of wood to distribute the load on the front and back may work, otherwise take it to a jeweler with the proper equipment. The thumb routine didn't work for me. I have a vice but figured many wouldn't so I tried something else first. I put the watch face down on a piece of wood. I found a small 2" long scrap of wood (3/4" x 1.5" approx) that spanned the back. I centered the back (aligned properly) placed the block of wood squarely and centered across the back and tapped the end of the block with a hammer. First try didn't work, second one did. I used a rubber mallet as the hammer but a regular hammer or other heavy object would work. The trick, I think, is to get everything lined up and square so the blow is centered and even. Also, I'd suggest cleaning the back and the groove in the case and be sure the rubber gasket is properly positioned. This will give you the best chance of retaining the waterproofing. And remember to check that the watch is running before you do this. Some need to be reset (usually with a very small screwdriver or pin) after replacing the battery. There should be a small hole with some printing next to it. You may need a magnifying glass to see/read it. Good Luck, Richard
Timex Expedition... | Answered on Oct 29, 2013
how much is this worth my uncle gave it to me
Timex Expedition... | Answered on Oct 08, 2012
you need to take the movement out of the case and press it back on the link below will assist you in doing this and meny other problems you have..
http://www.pmwf.com/Watches/Watches.htm#WatchSchool
Timex Expedition... | Answered on Aug 29, 2012
bad movement, get a refund or replace the watch
Timex Expedition... | Answered on Jan 17, 2012
Timex Expedition 40141 Wristwatch Logo
81 questions posted
Top Timex Watches Experts
Janelle Schoonover
Janelle Schoonover
MrFixitSTTL
pacdave
Are you a Timex Watch Expert? Answer questions, earn points and help others
View Most Popular
Expedition Timex
  • Expedition Timex
Most Popular Question
get stem out
  • Watches
