20 Most Recent Timex Automatic Watch Questions & Answers
2answers
My timex watch changes the date at noon instead of
This is because you have reversed am with pm.
Set your watch 12 hours back and the problem should be solved.
You might want to wait till midnight or noon to check it's fine.
Note: if you see the day shows the previous day rather than the present day, you have to set the clock 24h ahead.
Problem solved!
11/9/2023 9:25:18 PM • Timex Automatic... • Answered on Nov 09, 2023
2answers
I have a Timex automatic with day and date. How do
I often sell vintage Timex watches which have a day and date feature. Setting the day and date feature can be a little tricky - if not frusterating if you aren't familiar with how to do it since most of the original manuals that came with these are long gone!I'll try to explain the process - please feel free to contact me if this doesn't make sense.1. Pull out the crown on the right hand side of the watch.2. Advance the crown so the time advances clockwise until the day is correct.3. Rotate the crown so the time is going counter-clockwise (the opposite direction) until the date "clicks". (the day will click first, then the date).4. Rotate the crown so the time is going clockwise again and the date will advance.5. Continue this back and forth action of rotation until the date is correct.6. Push in the crown and you're done!I'm considering making a video of this process. Please let me know if this is something you would be interested in.
1/25/2013 9:04:26 PM • Timex Automatic... • Answered on Jan 25, 2013
I have an old timex watch that was part of
"Automatic" watches are spring driven self winding.
If it is very old and does not run well, then it may need cleaning.
10/5/2011 2:28:30 AM • Timex Automatic... • Answered on Oct 05, 2011
GLASS BROKEN
take it to your local jeweler and they should be able to replace the glass for a small fee good luck!
9/4/2011 11:10:26 AM • Timex Automatic... • Answered on Sep 04, 2011
How do I reset the
mcdevito75 here, You re-set the time in a different time zone the same way as you do for the time zone your in now. The different time zones in the USA ru from 1 to 3 hours before the time in the Eastern part of the USA, example, Eastern time 3 PM, then going West, you have Central time 1 hour before, then Mountain time, 2 hours before , then Pacific time 3 hours before eastern time.
8/10/2010 1:32:53 AM • Timex Automatic... • Answered on Aug 10, 2010
Dont know how to set date on an automatic watch
mcdevito75, Here, You can set the date on your Timex Automatic, by simply slipping your fingernail just under the stem (winder) and gently lift it up to it"s first position (notch), this will allow you to turn the stem to change the date without haveing to turn the hands so many times. once set push the syem back in.
6/23/2010 6:55:17 PM • Timex Automatic... • Answered on Jun 23, 2010
Is there a manual for Timex women's T5K187?
https://www.google.com/search?q=Timex+women%27s+T5K187+manual It looks like you will have to contact Timex direct as the manufacturer doesn't list a manual for it although they do have other Ironman models. ..
3/9/2024 6:18:04 PM • Timex Watches • Answered on Mar 09, 2024
I left my timex solar watch in my watch case too long - and it stopped working. How do I repower the watch. (I have had it out in sunlight for a couple of days).
I am thinking you need a new battery. It appears to be a battery operated watch that runs on solar power IF there is light. How long will a Timex Solar watch last? The solar movement functionality creates an environmentally-friendly and maintenance free timepiece that can be charged through indoor fluorescent light or outdoor sunlight. Once fully charged, the battery life can reach two months. If worn daily, there is very little chance the watch will stop.
Solar Powered Watches ' Timex Blog
11/30/2023 7:43:05 AM • Timex Watches • Answered on Nov 30, 2023
Timex Expedition with Hydra Timer started randomly changing time and functions. Battery was replaced 1 year ago.
Either a loose connection inside or it just needs a new battery. They can be power hungry depending on how you use it and what battery technology type was used in the last one.
How Long Do Timex Watches Last? (Watch & Battery Life)
watchesoftoday.com https://watchesoftoday.com > Blog A Timex watch battery will last between two and five years, depending on how often you use the Indiglo feature, while the watch itself can easily last five to ...
8/26/2023 1:47:55 AM • Timex Watches • Answered on Aug 26, 2023
Battery replacement Timex T2H381
This will depend on the back of the watch. Totally smooth watch back is usually a push fit. Using a small precision screwdriver you Gently lever around the back plate until it 'Pops' off. the battery should hook out by CAREFULLY using the screwdriver you used to remove the back plate. *Note* check which way up the battery is fitted BEFORE you remove it. The back plate should just push on and should quietly click when seated correctly. Some back plates are 'screw on'. You can usually spot these by the dimples or notches on the back plate where the removal tool fits.
8/14/2023 8:57:55 AM • Timex Watches • Answered on Aug 14, 2023
Manual for timex TW4B02500CS
Instruction Manuals, User Guides and Downloads timex.cahttps://www.timex.ca Celebrating 165 Years of Innovation in Timekeeping. Discover More From Timex. Free Standard Shipping. New & Classic Styles. Styles: Metropolitan+, Waterbury, One GPS+, Weekender, Expedition, Intelligent Quartz, Originals. Shop Best Sellers. Rating for timex.ca: 3.7 - 209 reviews - Return policy: Most items 30+ days
Expedition North TitaniumBuilt With the Strongest Materials, Shop The Expedition North Titanium
Timex® New ArrivalsShop Our Newest Watches & Enjoy Free Shipping Worldwide.
Shop Marlin® Sub-DialA Modern-Retro Update To Our 1960s Marlin. Sharp Enough For Any Outing
Search Results
Watch Instructions & Manuals
Timex https://www.timex.ca > watch-manuals Instruction Manuals, User Guides and Downloads. Search for documentation for your Timex by entering the name, product number or feature. Sort by name ...
Timex M EXPEDITION GRID SHOCK WATCH, ... - manualzz
manualzz https://manualzz.com > Fashion & style > Watches View online or download PDF (301 KB) Timex M EXPEDITION GRID SHOCK WATCH, TW4B02500 Instruction manual • M EXPEDITION GRID SHOCK WATCH, TW4B02500 watches ...
7/10/2023 5:10:55 PM • Timex Watches • Answered on Jul 10, 2023
Timex T5K143 Ironman. How do I get a replacement band for the watch please?
Question edited for clarity.
Replacement Watch Bands & Straps
Timex https://www.timex.ca > browse > replacement-straps Replacement 18mm Resin Strap for Ironman® Essential 10 Full-Size. C$ 15.99. Strap Only StrapOnly. Replacement 20mm Bracelet for Highland Street Gray large.
  • Replacement 20mm Resin Strap for IRONMAN Classic 30 ...
    https://www.timex.ca > Replacement-20mm-Resin-Stra... Replacement 12mm Resin Strap for Ironman Essential 10 Mid-Size. C$15.99 ... I had to have a jeweler mill down some of the plastic so the band would fit. "); background-repeat: repeat-x; display: inline-block; overflow: hidden; position: relative; background-size: 14px 11.4px; height: 11.4px; width: 68px;">"); background-repeat: repeat-x; display: block; background-size: 14px 11.4px; height: 11.4px; width: 42px;"> Rating: 3.1 · ‎8 reviews
Timex Ironman Watch Bands Replacement
Amazon.com https://www.amazon.com > timex-ironman-watch-ban... 5pcs Compatible with Timex Ironman Classic 30 Watch,Ironman Essential 10 Mid-Size Watch Replacement Silicone Band Holder Loops with a Tool to Remove The ...
Replacement Straps for TIMEX IRONMAN Watches
Timex https://www.timex.com > browse > ironman-replaceme... Replacement 15mm Silicone Strap for Ironman Essential 30 Gray large ... Replacement 18mm Resin Strap Watch for Ironman 100 Lap Modular Black large.
Total Watch Repair https://www.totalwatchrepair.com > collections > timex... Total Watch Repair sells Timex Ironman Watch Bands and Replacement Straps online. ... Timex Ironman Indiglo Triathlon Shock Black 18mm Rubber Watch Band.
Timex Resin Wristwatch Bands for sale
eBay https://www.ebay.ca > ... > Wristwatch Bands 44 Results ; 14mm Timex Ironman 30 Lap Navy Blue Ladies Replacement Watch Band TX754261T. C $20.28. C $48.76 shipping ; 15mm Timex Ironman Triathlon Blk/Orange ... ..
5/4/2023 3:06:06 AM • Timex Watches • Answered on May 04, 2023
I Don't know to set up of the TIMEX DIGITAL WR100M IRONMAN CLASSIC 100 THAT I JUST GOT/// HELP
A lot of watch manufacturers use the American style date layout of Month/Day/Year. Try this. Looking at the watch press and hold the bottom right SIDE button for 3 seconds. It should enter setting mode where the seconds display will flash. Press the Right FACE button once. It should switch to the Hour display flashing. Press the same button again to go to minutes and them again to go to the date display. Repeated pressing of the top Right SIDE button changes the numbers upwards, (1,2,3,4), and the Left FACE button changes the numbers downwards, (4,3,2,1). Press the Bottom right SIDE button once to finish and go back to the normal display. http://assets.timex.com/manual/W-9.pdf
3/23/2023 6:21:08 PM • Timex Watches • Answered on Mar 23, 2023
Has Timex come up with a solution for all the Expedition watches losing time?
We aren't Timex, we are Fixya. Contact them direct. Make sure you are using the right compound of battery, not just the right size. https://www.google.com/search?q=Timex+Expedition+watch+that+keeps+losing+time https://www.fixya.com/support/r27181038-changing_watch_batteries ..
3/9/2023 6:10:06 AM • Timex Watches • Answered on Mar 09, 2023
2answers
How to reset my timex 637 t5g951 wr 30 heart monitor
To reset your Timex 637 T5G951 WR 30 heart monitor, you can follow these steps:
  1. Press and hold the "Mode" button on the front of the watch for three seconds until the watch display shows "Settings."
  2. Press the "Next" button on the side of the watch to scroll through the settings menu until you reach "Reset."
  3. Press the "Mode" button to select "Reset." The display will show "Yes" and "No."
  4. Use the "Next" button to scroll to "Yes," and then press the "Mode" button to confirm.
  5. The watch will reset and return to the time display.
Note: Resetting your Timex 637 T5G951 WR 30 heart monitor will erase all your saved data and settings, so you will need to set it up again after the reset. If you need to keep your data, consider transferring it to another device before resetting the watch.
3/3/2023 5:47:16 AM • Timex Watches • Answered on Mar 03, 2023
3answers
Manual for a Timex T5K360 Ladies Marathon Watch
https://www.timex.com/watch-manuals.html I didn't see it there, but they usually provide contact information to request assistance. https://www.amazon.com/Marathon-Timex-T5K360-Digital-Mid-Size/dp/B00284C9SM Amazon vendors often answer customer questions on their web site. Examples: Question: does this watch count distance? Answer: No, this watch does not count distance. It has two time zone settings and a stop watch. By Mindyx on June 24, 2017 See more answers (4) Question: Does this watch show seconds as well? Answer: Yes. By Mom of three on July 22, 2017 Yes the seconds show on the face along with the time. By Pati D on July 21, 2017Collapse all answers Question: What is the length of the watch band - I need at least 8" in length Answer: 6 inch By PromenadeWatches SELLER on August 4, 2017 Tip to tip (including buckle) is 9 inches. 8 inches without the buckle By Brittney on August 1, 2017 Hello, standard wrist size for a women's watch fits a maximum of 7.5 inches. By Timex Customer Service MANUFACTURER on August 3, 2017 Collapse all answer Question: IS this a chrono watch? Answer: Hello, thank you for your question. Yes this watch has the chronograph feature. By Timex Customer Service MANUFACTURER on August 29, 2017 No, it is not a chrono watch, but it has a 24-hour stop watch. By Mindyx on August 28, 2017Collapse all answers Question: Does this watch have presets for the countdown timer? For example 30 secs, 1 min, 3 min, 5 min, 15 min, 30 min, 45 min, 1 hour? Thank you! Answer: No By Mom of three on February 16, 2018 Hello, thank you for your question! This watch doesn't have timer feature. By Timex Customer Service MANUFACTURER on February 20, 2018 Collapse all answers
Question: Does this watch have a countdown timer? Answer: Yes, this watch has a 24 hour countdown timer. By Timex Customer Service MANUFACTURER on March 13, 2017 No. But the size of the numbers and night light button are great features. Has count UP timer. By Mom of three on March 13, 2017 Collapse all answers Question: How do I change the time showing back to international (military) time? Answer: By pressing the lower left hand button to scroll through he screens, go to where it displays the time with the date up above. Press the upper left hand corner button once. By Mom of three on August 16, 2017 Hello, thank you for your message. Here are the instructions in setting the time including the time format. To set time and date: ... see more By Timex Customer Service MANUFACTURER on August 15, 2017Collapse all answers
3/1/2023 8:14:33 AM • Timex Watches • Answered on Mar 01, 2023
Timex Automatic Watch Logo
Popular Tags
12 questions posted
Top Timex Watches Experts
Paul Bade
NOEL
NOEL
Ngoro
Are you a Timex Watch Expert? Answer questions, earn points and help others
View Most Popular
Timex Watches
  • Timex Watches
Most Popular Question
timex automatic day date
  • Watches
