Dishwashers Logo
S
Stewart Williams Posted on Nov 15, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Where/How can I purchase a Cutlery Basket for a AEG OKO FAVORIT 6050 Model Dishwasher? Online OR through a retail outlet? Regards Stewart Williams
schwaa44
Level 3:
Master:
  • Master 252 Answers
  • Posted on Nov 15, 2016
schwaa44
Master
Level 3:
Master:
Answers
252
Questions
0
Helped
127383
Points
1401
Online. I found two different places. http://shop.aeg.co.uk/category/Dishwashers/Dishwashers
1helpful
Aeg oko favorit 40300 service manual
AEG OKO FAVORIT 40300 When switching dishwasher on no water is flowing into the the dishwasher
Please help
Need an outlet hose for an AEG 6050 model. Where can I get one ?
That is not that hard to fix and you can easily buy the parts yourself online...
Here is a tip that will help you with the online buying...
How to Buy
Appliance Parts Online
heatman101
What is the most usual reason for leakge on the AEG 6050?
The outlet pump is triggered by the anti flood micro switch via the polystyreene float on the base of the washer. If any water for whatever reason (leaky pipe)is on the floor the machiene automatically switches to pump out mode and only works once the water and the cause is rectified..
AEG OKO FAVORIT 6050 trips earth leakge
This is typical of a water leak onto electrical connection OR the electrical element has shorted internaly . Check this with a Ohm meter and itshould show the problem
20helpful
3answers
The drain pump on the AEG oko favorit 6050 keeps running even when the on/off switch is off or the door is open.
Empty all the water from the salt resevoir, (I used a turkey baster), then rock the machine backwards and forwards a few times and empty the last few drops from the resevoir again.
15helpful
3answers
Drain pump keeps running AEG oko favorit
This seems like the anti flood system (polystireen float / micro switch) at the base of the washer is triggered,\. This puts the washer in pump out mode and stops inlet of water via the inlet solinoid. Dry the water on the base and then check for any water leaks. (pipe leak
Top AEG Dishwashers Experts
Paul Carew
Dominic Harborne
Level 1 Expert
Kolbrun...
Are you an AEG Dishwasher Expert? Answer questions, earn points and help others
