If you have a router with a USB port that is working as a print server, check the router administration page (usually 192.168.1.1) for a network map. There should be an option to look up the specifics of the devices, including the IP address. Note: you may need to install software from the router manufacturer to enable this print server function. On my router, I found a link to this software on the router page in the section for setting up the USB devices. When I had a printer connected to the router, I had to connect the printer to each computer via the USB cable in order for the drivers to load. Then the software could identify the printer during the setup when the printer was connected to the router.
If you are trying to use one computer with a USB connection to the MG2120 as the print server, you'll need to enable device sharing. Then let the other computers find that system. The address of the printer will end up similar to a folder of the directly connected computer (print server). Note: I know how to do this with Windows OS machines. I'm not sure if it works with iOS and Android devices.
Methods that Setup Canon Pixma Ip2820 Printer Easily:-
1. Keep your Canon Pixma iP2820 printer on a place where you can handle it easily.
2. Insert the cartridges into the preferred slots.
3. Connect the power cable of the printer to complete the printer setup process.
If the Set-up does not work To Setup Canon Pixma Ip2820 Printer, you want to join with Printer Error Support experts. You can also follow the easy steps to Setup Canon Pixma Ip2820 Printer are given below in the BLOG link.
im unaware that cannon software runs on a tablet (android) , but you can remove the storage card and buy a usb card reader to connect to tablet to see photo with (jpeg format only) , also another way is to use a digital photo frame , connected to a wifi router ! ive done this 4 show demo's and stuff it works fine !!
Are you close enough to the printer? Bluetooth range is only about 6 feet max. is the printer wi/fi capable? Print to google cloud print and associate it with your printer.
hi,
to get a page printed by your samsung galaxy tab you need to open the page you wanted to be printed and the select a printer your icon at the top of your screen then the tab wil automatically detect the printer will give you the print of the required page. Hope you get your problem fixed, If found any difficulties feel free to contact me anytime. Thanx
