Cars & Trucks Logo
B
Boyd Jones Posted on Oct 10, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Occasionally, about every 6 to 8 times tried, the engine will turn but not start. If I turn the key off for about 3 seconds, it usually starts within a few turns. Do you know what can cause this?
Jeremy W.
Level 3:
Top Expert:
  • Cars & Trucks Master 5,332 Answers
  • Posted on Oct 10, 2016
Jeremy W.
Level 3:
Top Expert:
Answers
5332
Questions
0
Helped
2060479
Points
17799
A year, make, model, and engine size would help but I will through this at you.
Instead of just trying to start the car turn the key to the run position and wait 3 seconds. Turn the key off and immediately turn the key back to the run position and wait another 3 seconds. Turn the key off then try to start. Do this every time you try to start the car. If you symptom never occurs when you start the vehicle like this than I would suggest taking a closer look at the fuel system.
I’m happy to assist further over the phone at https://www.6ya.com/expert/jeremy_d728a59f986299fa
Testimonial: "This may be a patch but doesn't address the problem."
  • 1 more comment
  • Jeremy W.
    Jeremy W. Oct 10, 2016
    I need more info to address the problem more directly. That's why the year make and model will help tremendously. The info provided is merely a diagnostic step that may help determine the direction of more testing. if the problem stops using this technique it is almost always a fuel issue. A fuel pressure gauge can be used to detect falling fuel pressure caused by a bad injector, bad fuel pressure regulator, or even a bad fuel pump.
  • Boyd Jones
    Boyd Jones Oct 10, 2016
    This information in the field below the question, but here it is again: 2001 Mercury Mountaineer, 5 liter
  • Jeremy W.
    Do you notice this symptom after the car sits for about 15 minutes after driving until the engine is completely warm. For example, you drive 20 minutes and pull into the bait shop. You shut the vehicle off and run in for some minnows and a dozen night crawlers. You come back out to the vehicle and try to start but it doesn't?
2helpful
8answers
How do I rest oil change light on a 2001 1500 silveradeo?
Place a piece of black electrical tape over it ,problem solved .you know the oil is good
Programming keyless entry to 95 landcruiser
1. Start with key out of ignition, drivers door is open all others closed and
drivers door is unlocked.
2. Insert key into the ignition (Do NOT Turn) and Pull key out.
3. Perform these steps within 40 seconds.
A. Using the power lock switch on the drivers door, perform 5 lock/unlock cycles
starting with lock. Use an even pace and try to go about one cycle per second.
(1Cycle = 1 lock and 1 unlock).
B. Close, then open drivers door.
4. Perform these steps within 40 seconds.
B. Insert the key in the ignition cylinder.
C. Turn the ignition to ON (Do NOT Start) then back to OFF.
D. Remove the key from the ignition.
5. Within 3 seconds the power door locks should cycle automatically indicating successful
entry into programming mode. Return to step 1 if the locks do not cycle at this point.
6. Perform these steps within 40 seconds.
A. Press the lock and unlock buttons on the remote simultaneously for 1 second.
B. Immediately after letting go of the lock and unlock buttons, press the lock button by
itself and hold for 2 seconds. Within 3 seconds, the door locks should cycle once
indicating successful programming. If the door locks do not cycle, or cycle twice.
repeat steps A and B in step 6 as your remote has not been accepted.
C. Repeat steps A and B in step 6 for each new remote.
7. Close drivers door.
6helpful
2answers
How do u reset thechange engine oil light after u changed the oil in the instrument cluster 2003 chevy monte carlo
TURN KEY ON, DO NOT START! PUMP GAS PEDAL TO THE FLOOR 3 TIMES WITHIN 5 SECONDS, THEN WAIT AND WATCH THE LIGHT IT WILL FLASH THEN IT SHOULD GO OUT. REPEAT IF IT DOES NOT WORK THE FIRST TIME. MOTOR62500!
2answers
I have a99 mercury mountier with anti theft problems some times it won't start with out resting the system through the door lock click 3 times what's up?
are you using a copy of the original key
you need to use the original key for the car
Antitheft and Alarm Systems: Description and Operation
ANTI-THEFT
The passive anti-theft system (PATS) uses radio frequency identification technology
to deter a driveaway theft. Passive means that it does not require any activity from
the user.
The PATS uses a specially encoded ignition key. Each encoded ignition key contains a
permanently installed electronic device called a transponder. Each transponder
contains a unique electronic identification code, with over 72 million billion
combinations.
Each encoded ignition key must be programmed into the vehicle powertrain control
module (PCM) before it can be used to start the engine. There are special diagnostic
procedures that must be carried out if new encoded ignition keys are to be
configured.
The encoded key is larger than a traditional ignition key. The key does not require
batteries and should last the life of the vehicle.
The transceiver module communicates with the encoded ignition key. This module is
located behind the steering column shroud and contains an antenna connected to a
small electronic module. During each vehicle start sequence, the transceiver module
reads the encoded ignition key identification code and sends the data to the PCM.
The control functions are contained in the PCM. This module carries out all of the
PATS functions such as receiving the identification code from the encoded ignition
key and controlling engine enable. The PCM initiates the key interrogation sequence
when the vehicle ignition switch is turned to ON or START.
The PATS function uses the PCM to enable or disable the engine. All elements of PATS
must be functional before the engine is allowed to start. If any of the components
are not working correctly, the vehicle will not start.
PATS uses a visual theft indicator located on top of the instrument panel. This
indicator will prove out for three seconds when the ignition switch is turned to ON
or START under normal operation. If there is a PATS problem, this indicator will
either flash rapidly or glow steadily (for more than three seconds) when the ignition
switch is turned to ON or START. PATS also "flashes" the theft indicator every two
seconds at ignition OFF to act as a visual theft deterrent.
The PATS is not compatible with aftermarket remote start systems, which allow the
vehicle to be started from outside the vehicle. These systems may reduce the vehicle
security level, and also may cause no-start issues. Remote start systems must be
removed before investigation of PATS-related no-start issues.
The PATs key is used on the following Ford family trucks and suvs:
FORD: 1996-2001 MUSTANG, TAURUS
1998-2000 CONTOUR
1998-2001 CROWN VICTORIA
2000-2001 FOCUS
2002 THUNDERBIRD
1997-2001 EXPEDITION
1998-2002 EXPLORER
1999 F-250 LD
1999-2001 F-150, RANGER, WINDSTAR
2000-2001 EXCURSION
2001 ESCAPE
LINCOLN: 1997-1998 MARK VIII
1998-2001 CONTINENTAL, TOWN CAR
2000-2001 LS
1998-2001 NAVIGATOR
2002 BLACKWOOD
MERCURY: 1996-2001 SABLE
1998-2000 MYSTIQUE
1998-2001 GRAND MARQUIS
1999-2001 COUGAR
1998-2002 MOUNTAINEER
Additionally, PATs can be found on the follow Ford family cars and mini-vans:
1998-up Contour
1997-up Crown Victoria
1999-up Escort
2000-up Focus
1996-up Mustang and Taurus
1998-up Windstar
1998-up 2000-up Lincoln LS
1998-up Lincoln Mark VIII, Lincoln Continental and Lincoln Town Car
1997-up Mercury Grand Marquis
1998-up Mercury Mystique
1996-up Mercury Sable
Following are the instructions for programming a blank key (you must have at least one working key for this procedure).
The PAT
1. Make sure you have both keys.
2. Turn on car but don't start. Watch "theft" indicator untils it goes out.
3. Turn off and repeat procedure with second key.
4. After "theft light goes out, insert new key and turn on.
5. Wait until the theft indicator goes off and then turn off switch.
6. Wait thirty seconds. New key is now programmed into security module. Repeat for any other keys.
1. Erase any old codes by entering the factory code.(buttons will light up)
2. Press 1/2 button within 5 seconds.
3. Press 7/8 and 9/0 buttons at the same time within 5 seconds.
To set new code:
1. Enter factory code (numbers will light up)
3. Enter personal 5 digit code(decide beforehand) within 5 seconds of each previous one.
To unlock all the doors,press the 3/4 button within 5 seconds of the driver door unlocking.
To lock all doors and set alarm system,press 7/8 and 9/0 at the same time.
To disarm or reset a triggered alarm,just enter personal or factory code.
Do not set a code with five of the same consecutive numbers. It's too easy for thieves to figure out.
Deactivating and Activating Autolock
To deactivate the "autolock":
With all doors and tailgate closed but NOT locked,and ignition OFF.
1. Enter 5 digit code
2. While holding 7/8 button in, press and release the 3/4 button.
3. Release 7/8 button
The horn will chirp once if the "autolock" was deactivated
or two times if "autolock" was activated.
To reactivate the system,repeat steps 1 thru 3
Alternate Method To Deactivate And Activate Autolock
Do steps [1] through [5] (below) within 30 seconds or you'll have to do it over. If you have to do it over, wait 30 seconds between attempts.
Close all doors securely.
1.Turn the ignition key to ON.
2.Press the power door UNLOCK control THREE times.
3.Turn the ignition key from ON to OFF.
4.Press the power door UNLOCK control THREE times.
5.Turn the ignition key back to ON .The doors should lock and unlock.
6.Press the power door UNLOCK control. The horn should chirp ONCE to confirm successful switching of the autolock system
Troubleshooting:
The engine does not start and LED remains off.
1. Check PATS system fuses
2. If alarm is fitted check if LED functions for alarm: if not check cigar lighter fuse (also used for LED)
3. If not go to main dealer
Engine does not start: LED flashes rapidly Leave ignition on until the LED starts to flash a 2 digit code: (sequence- pause-sequence)
Check the following codes:
Code flashes:
1:3 Key code not received. Is key screened by other keys or objects? Try different key: if okay then first key is faulty. If not go to main dealer
1:4 Partial code only received. Try again. If not okay use different key. If not go to main dealer
1:5 Key not programmed into PATS. Program key as above using master
1:6 Faulty link between PATS module and EECV Go to dealer .
3answers
Oil change light wont go out on a 1999 grand am
Hello Dyno.
Have you tried using this procedure to turn it off?
OIL LIFE MONITOR SYSTEM
Resetting Procedure
  1. Turn the ignition to the ON position, engine OFF.
Drivers Side I/P Fuse Block 86382201
  1. Press and release the RESET button on the drivers side I/P fuse block.
    • The CHANGE OIL indicator will start flashing.
  1. Press and hold the RESET button until an audible chime is heard and then release.
    • If the CHANGE OIL indicator comes back on, the system did not reset. Try the procedure again.
2answers
2007 Toyota Tacoma key fob
no.. u need to have a dealer do it.. they also have a tool ti check it the remote is transmitting a signal as well
2answers
How do we get the check engine oil light off of a 1999 chevy 6 liter
First turn the key to the run position, (not start). Push the gas pedal down to the floor 3 times within five seconds. Turn the key off and then cycle back on and start the truck. The indicator should flash five times and go out.
It may take a few tries.
2answers
How to program the key for my bmw 750i model 1997 to lock/unlock the door
BMW 7-Series - Key Remote Programming
Three methods to try:
Method 1:
1. Working from within the vehicle and with the doors shut
2. Turn ignition to position 1 and back to off within 5 seconds.
3. Remove the key from ignition and press and hold the unlock button for 15 seconds during this time press the key lock button 3 times within 5 seconds.
4. Release both buttons.
5. Doors will lock and unlock to show correct programming has occurred.
Method 2:
To do this procedure you need to have one working key and one key that needs to be programmed.
1) Get in and close all doors.
2) Turn on the ignition and turn off quickly. (No more than 5 seconds) to start the process. Next action must take place within 30 seconds.
3) Remove the 1st key.
4) Hold the key up near your left shoulder (this is so it is closer to the remote receiver antenna.
5) Hold down the unlock button and press the lock button 3 times. Release the unlock button and the doors lock which confirms the operation.
6) Quickly repeat steps 4 & 5 for key #2 etc.
If it does not work, try doing the keys in opposite order. Key 2 then key 1, vs 1 then 2.
Method 3:
Alternate if you do not have a working remote
1. Turn key to position 1 five times very quickly 2. Remove key 3. Hold unlock button then press lock button 3 times, release unlock button.
4. If you have another key do the same button pressing within 30 seconds 5. Turn on ignition to finalise.
PLEASE NOTE: This programming procedure programs the remote control part of the key. Any transponder chip for the immobiliser (starting of car) will not be programmed and must be done by a specialist.
window.google_render_ad();
Engine won't start first time, but will after short pause on second attempt
try this turn key on but don't crank count to five and do it once more now turn key off and then start if it starts right up by doing this the fuel pump is loosing it's prime it has a check valve in the pump that sticks
Top Cars & Trucks Experts
ZJ Limited
ZJ Limited
john h
Arnie Burke
Arnie Burke
Are you a Car and Truck Expert? Answer questions, earn points and help others
