E-Machines eMachines Refurbished EMA SYSTEM BOARD MODEL T2984 eMachines (102257) PC Desktop Logo
Debbie Lewis Posted on Oct 03, 2016
I have an e machine and forgot my password.Itried using the F8 button to get in the safe mode, but no administrator account comes up. I have no disk to do a password reset either. What can I do now?
leonardopcos
Level 1:
  • Contributor 24 Answers
  • Posted on Oct 03, 2016
leonardopcos
Contributor
Level 1:
Answers
24
Questions
0
Helped
3966
Points
57
You will need the help of a bootable DVD or USB stick. You have a few options, but you need another working PC. If your notebook have Windows 7, you can download and burn the utility "Offline NT Password". Other good tool is the Hiren Boot CD, that can also be put on a USB stick. If you have Windows 8 or 10 there's a trick using the 'utilman.exe' executable that can change the password or create a new user. Both ways will require some work.
1 Related Answer
Anonymous
  • 7 Answers
  • Posted on Mar 29, 2012
SOURCE: If you lost windows password, you can go into safe
I read a good tutorial on computer password change, you can Google search its title:
Reset administrator Password ' Free and Fast Methods to Reset Administrator Password
Different Types of Computer Password
' How many passwords do you know on a PC?
I forgot my laptop password ,how do i reset it
Option 1: Windows 7 Password Reset in Safe
Mode via Administrator
Follow below mentioned steps under this option:-
1. Boot or reboot your Windows 7 PC or laptop.
2. Press F8 repeatedly until the Windows
Advanced Options Menu screen appears.
3. Select Safe Mode in the coming screen,
and then Press Enter.
4. Log in Windows 7 with Administrator account
when you see login screen.
5. Click Start > open the control panel >
users accounts, and select locked administrator to reset its password. Or run
command prompt as administrator to reset Windows 7 password with net user
command.
Option 2: Reset Windows 7 Admin Password with
Reset Disk
1. Click Reset Password and password reset
wizard appears.
2. Click Next and insert Win 7 password key
disk(password reset disk) into locked computer.
3. Choose recovery disk from drop-down box and click Next.
Then follow the wizard to do step by step.
4. Until it asks you to set a new password for Windows 7
administrator. Just type new one and confirm it.
5. Click Finish finally to complete Windows 7
forgotten administrator password reset.
http://qwikfix.co.uk/acer-customer-service/
coraltomReply2016-07-15
Start up your computer in safe mode, by default the built-in administrator account has no pa
tip
How Do I Reset Laptop Password to Break into Laptop Login
"Help!!! How to recover my forgotten laptop password?" Situation is so urgent! Then search solutions online: laptop password reset, how to remove laptop login password? Carelessly, we forgot laptop password, then we now concentrate on how to unlock laptop password methods!
How do I recover laptop password on Windows Vista?
- Remove laptop Windows Vista password from Safe Mode
A. When laptop starts, please press "F8" key.
B. At the "Advanced Boot Options" windows, choose "Safe Mode with Command Prompt" and then login Safe Mode with available administrator account
C. Input "net user", press "Enter" key and then all the accounts will be listed.
D. Input "net user Lisa 012" (Lisa is the forgotten account name and the 012 is Lisa's related account password.), press "Enter" key to finish unlock laptop Vista password.
E. Input "shutdown -r" and press "Enter" to restart laptop, then we can login "Lisa" account again.
How to find laptop password for Windows 7
- Bypass laptop Windows 7 password with built-in administrator account
A. Power on laptop PC and press the key: F8.
B. At the windows of Advanced Boot Options, opt for "Safe Mode with Command Prompt" and confirm with key: Enter. Then PC starts Windows.
C. Select "Administrator" account shown on the account screen, and then access the windows - Administrator: cmd.exe.
D. Input command: net user Merry 123 and confirm with Enter. (Merry is the account required to reset password; 123 is the new password for account Merry).
Please note that the administrator account will be useful only we had set it enable. (The default status is disable.)
How can I Break password on laptop Windows XP
- Get into Windows XP laptop by default Administrator account
A. Press "F8" when laptop computer starts.
B. At the "Advanced Boot Options" windows, choose "Safe Mode" with arrow key and confirm with Enter key, then PC accesses Safe Mode.
C. Click "Administrator" on the Windows login screen.
Please note that if we have set the Administrator password before, we need to input the changed password instead of leaving "Password" field blank.
D. Start - Control Panel - User Accounts - Select the locked account and change password for it.
E. Restart laptop and login with the account newly reset password.
The above ways are referred to system with available account (default/built-in account or other accessible accounts with administrative privileges). While, if there is not other accounts to help us, how to reset laptop password?
Unlock laptop password with Installation disk: if there is not important data for us, we can use it for password unlock.
Laptop password bypass with password reset disk: we can use the disk only if we create the disk before lost password for the related account.
DIY a laptop password reset disk now: It is the last but not the least solution on laptop password recovery!
We need a CD/DVD/USB disk and an accessible computer to burn a .iso image file from Windows password recovery software! Take one of the most top-rated tools - Ainorsoft Windows Password Recovery Corporation as example:
A. Download Ainorsoft Windows Password Recovery Corporation and burn its .iso image file into a CD/DVD/USB Flash Drive from an accessible laptop;
B. Set PC with password locked to boot from burned CD/DVD/USB Flash Drive;
C. Reset forgotten laptop Windows password to a new one with the burned CD/DVD/USB Flash Drive.
Now, once we forgot laptop password, the last method will always make sure we reset password for laptop easily without IT expert knowledge.
Source: http://windowspasswordrecovery.net/article/laptop-password-reset.html
on Jul 15, 2011 • Computers & Internet
I forgot my pass code and lost my restart disk
OK, if you are running Windows 7, Microsoft tightenedsecurity on it so you've got to have a password reset disk which 99% of thepeople who own laptops with windows 7 fail to do. It should be one of thefirst things you do when you buy the laptop. Otherwise, you're faced withreinstalling the Operating System or possibly doing a System Recovery.
If you're on Windows XP or Vista try this:
Turn off the computer, then hit the power button to turn it back on andimmediately start hitting the F8 key repeatedly until you see the Safe Modeoption. Select SAFE MODE and let the computer boot up. When it getsto the User Login screen it will show the Administrator userid and the useridfor which you forgot the password. Sign in as the Administrator (hopefullyyou didn't put a password on it and forgot it too). Once the desktopappears it will look different, the screen will be darker and the icons bigger,but this is normal for safe mode.
Click Start/Control Panel/User Accounts
When the User Accounts screen opens, click on the userid for which you forgotthe password. Select the option to REMOVE PASSWORD.
Reboot your machine.
2helpful
2answers
Okay so my friend put a password on her sylvania laptop and she forgot it and now she wants to know how to get it to default settings can you help?
What the Os do you use?
Vista and Windows 7 allow you to create a password reset disk.If you installed Windows XP, boot up Windows XP in Safe Mode and log on with the built-in administrator account.
Besides,using WindowsPassword Reset is a good method.
In my experience,use windows password reset tool is the best method to reset windows password.
I forgot my gateway laptop password and can only get on guest. how do get in with out using a disk or usb?
restart the pc and then as soon as the black screen appears keep pressing f8 till the boot menu comes up, choose safe mode. when windows loads up in safe mode Login as Administrator then click start > control panel > users click on your account > click remove password. Restart pc and log in to your account
51helpful
18answers
I forgot my password on my computer
I know a windows password recovery tool called windows password buster. This software could help you recover the password.
9helpful
9answers
Can't get pass windows login forgot password for os how do i get in
I know a windows password recovery tool called Windows Password Buster. This software can help you reset the password.
6helpful
7answers
Locked out
you can try loggin on to safe mode suing F8 might be an option if you have not set the adminstrator password.
if you are able to log on in safemode you can go to user account under control panel and reset the pasword.
If you have password there too . you may need to have a windows xp cd to go to reocvery console
thank you
2answers
How to change windows password if i forget it
hi,
Press ctrl+Alt+Delete button twice to get "Log on to windows" screen. Now give "administrator" as user name and just Enter without typing password. your will be Logged in now.
Hope this Both videos will be so useful for you.
Thanks,
Appreciate to rate as "fixya"
Top E-Machines Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Andrew Chrostek
Andrew Chrostek
Level 1 Expert
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
