Printer will accept and print plain paper. When I try to print on 65# card stock or photo paper, I get an E message and a blinking red light.
SOURCE: Power on switch and orange arrow flashing, will not feed or print.
I had the same problem and found this solution. It worked for me, hope it helps you too.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=bpd09315&lc=en&cc=us&lang=en&product=60653&dlc=en
SOURCE: photo card inserted backwards error
Try a full NVM reset on the unit and check
Reset Steps are.
Unplug the power cord from the unit when there is still power in the All-In-One and press and hold the # and No 9 Button without releasing the buttons plugg the power cable back, it should come up with a message as reset
If the screen go's blank after you connect power cable, then release the keys and turn the power On, it will come up with a message as Full NVM Reset
Good Luck
SOURCE: I want to print a photo using the photo paper
I had to adjust the advanced print settings on my computer.
