Flashing 88:88 with set time above it. no4 in bottom left of screen. Kenmore Convection stove model: Cannot clear these flashing lights; can't use oven.
Have turned off power overnight & also unplugged for several minutes. Stove top works but oven does not.
I have a Samsung rf26xaewp side by side fridge that was built in 11/2009. On the front of ice maker the setting on the left is flashing 88. The setting on the right is bouncing between 88 an 89. I cleaned the back an looked at computer board, there is a red light on. Fridge feels like its thawing. Only thing ice maker will do is expense ice.
Press and hold the top left button until the seconds digits flash, indicating that you have accessed the time-setting screen. Press the bottom right button to reset the seconds to "00" and then press the bottom left button to advance the flashing to the hours digits. Adjust the hours digits to the desired time using the top and bottom right buttons. Press the bottom left button to advance the flashing to the minutes digits, and set them to the desired time with the top and bottom right buttons. Press the top left button to exit the time-setting screen. Have a nice day.
to clear the 991 Takagi code, simultaneously press the bottom 2 grey buttons of the four just to the left of the flashing LED light. When the LED stops flashing, release and then press the reset button on the black panel about 8 inches above that
Try pushing / stop reset first. The setting the time by pushing clock button .... punch in the time and push the clock button again. Just respond here if that does not work. 88-8888 is what you get after your first plug it in. Sometimes you will get PF if you unplug it and plug it back in. If that appears push stop / reset / clear. (Same button)
Hold the left button until it beeps. Hold the right button until it beeps. You should see flashing 00. Set the time by moving the right button. Then hold down the left button for a long beep. Then hold down the right button for a long beep.
\i have a stoves 900 GTF double gas oven. The clock has suddenly started to flash. It does not enable me to set the time and therefore I cannot use the main bottom oven. I am unable to overide the auto to manual. Can anyone help me with instructions or with solving this problem. I have mislaid by instruction booklet. Thanks.
is the control electronic wih a dial or the whole manual if you can answer me with the model number i can look it up there will be a serial plate some where on the front of the oven most of the time you open the bottom drawer mod#is a bunch of numbers like 106.48062890 should be able to help more after that
