20 Most Recent Kenmore 91112 / 91114 / 91117 Electric Kitchen Range Questions & Answers
Pf keeps flashing on oven wont respond to touch pad
Try setting the clock
9/26/2017 11:30:49 AM • Kenmore 91112 /... • Answered on Sep 26, 2017
0answers
Burner works intermittently
You have either a bad burner or a bad control for same, or bad connections. With power removed use a pair of pliers to crimp the connections (after cleaning the ones on burner) going to the burner.
6/17/2017 2:38:49 PM • Kenmore 91112 /... • Answered on Jun 17, 2017
2answers
Range started beeping and display "F10" code.
Hello & Welcome to FixYa
Error code F10 is displayed due to electronic oven control failure and the only way to solve this problem is by replacing the control board which is bad. Sorry for the bad news but hope you understand... Please get back to me if you have any other questions.
Kevin
2/26/2016 10:52:23 PM • Kenmore 91112 /... • Answered on Feb 26, 2016
2answers
Burners wont light
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
1/3/2016 7:02:12 PM • Kenmore 91112 /... • Answered on Jan 03, 2016
0answers
0answers
Kenmore inner oven glass cracked (911.93411002
I suggest you check www.repairclinic.com
They will answer your questions and may even have a better price on the replacement glass.
I have no affiliation, but have been pleased with their service.
3/4/2015 9:21:28 PM • Kenmore 91112 /... • Answered on Mar 04, 2015
How to check heating element
You can sometimes see the burnout of an element. In some cases it will actually burn a hole or melt a spot in the outer lining of the element. Sometimes it shows nothing. In that case it can only be tested with an ohm meter... Normal reading is approx 15 to 20 ohms. No reading at all means its burned out.
3/1/2015 2:16:12 AM • Kenmore 91112 /... • Answered on Mar 01, 2015
How do i open the oven windows to clean in between the 2 glasses
Assuming you've removed the door, lay it down on a blanket and look at the bottom. Usually there are 3 or 4 screws there - remove them. Then remove the 2 screws that hold the handle to the door. At this point, you should be able to separate and remove the outer door & glass panel. 90% of all your spills and drips can be cleaned at this point. I do not recommend taking the rest of the door apart, as it gets more complicated to disassemble and especially re-assemble correctly. If you need further help, reach me via phone at https://www.6ya.com/expert/ronald_e6b9572cebe3ad27
1/27/2015 5:01:34 AM • Kenmore 91112 /... • Answered on Jan 27, 2015
Why does the set clock time keeps blinking even after I reset it
This is a "feature" imposed upon us by those energy-saving freaks and environmentalist-wackos. What you need to do is press and hold the clock button for 12 to 15 seconds. When you first press this button, the display will appear. Then in about 7 or 8 seconds it will disappear. Keep holding it for 12 to 15 seconds until it re-appears. Now if you release the clock button, it should remain on. If you need further help, reach me via phone at https://www.6ya.com/expert/ronald_e6b9572cebe3ad27
1/3/2015 8:11:18 AM • Kenmore 91112 /... • Answered on Jan 03, 2015
WHAT DOES IT MEAN WHEN F10 APPEARS AND BEEPS? HOW DO I FIX IT?
I think this means that the oven is over-heating - caused by a relay that is stuck closed on the Electronic Oven Control. You will have to replace that EOC. If you need further help, reach me via phone at https://www.6ya.com/expert/ronald_e6b9572cebe3ad27
1/3/2015 8:10:10 AM • Kenmore 91112 /... • Answered on Jan 03, 2015
2answers
Kenmore oven control beeps and shows F1
According to Kenmore's list of error codes, F1 means EOC (Electronic Oven Control) failure, and the solution is to replace the EOC. You might look into that. The part itself costs around $80, as far as I can see.
11/26/2014 10:49:04 PM • Kenmore 91112 /... • Answered on Nov 26, 2014
Ignitor isnt working
The oven ignitor should have a resistance reading of about 3.2 to 3.6 ohms. If the readings are out of this specification or show open replace the ignitor. measure the resistance of the oven valve. The gas valve should have about 1.5 ohms of resistance. If the gas valve is OK, the control board is suspect. The ignitor needs 120vac to work.
4/7/2014 6:19:38 PM • Kenmore 91112 /... • Answered on Apr 07, 2014
Kenmore 91112 / 91114 / 91117 Electric Kitchen Range Logo
279 questions posted
Top Kenmore Kitchen Ranges Experts
Paul Carew
ZJ Limited
ZJ Limited
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
View Most Popular
  • Kenmore Kitchen Ranges
Most Popular Question
open oven windows clean in between 2
  • Kitchen Ranges
