20 Most Recent
Kenmore 78812 / 78814 / 78819 Gas Kitchen Range Questions & Answers
Kenmore Gas Stove gas takes a long time before it will come out
First, I'm not a Kenmore Tech.
* call vendor for service. Gas leaks are hazardous and require a qualified tech to service.
*** The following is for information only.***
* I've always had problems servicing gas stove, heaters, boilers, etc. Lots of unique components that require special tools to service.
* I was surprised to find out that it's better to call on your local Gas Supplier for service. The not only check the supply line but also have a very good working experience with all types of gas fired equipment.
* Slow pilot lighting or burner fire usually means a clogged gas vent or valve. If other burners are working fine, then it's just that particular burner.
* If all burners have the same symptom then it could be a number of things.
* Check gas mains for pressure and flow (you need a gas meter for this but if you have another stove on the same line then it's probable that the mains are okay. Unless the connector or shutoff valve is not working properly (partial open).
* Check gas hose to stove for kinks. Replace if bent (re bending will crack a metal hose.)
* Check the gas regulator (again, need a gas meter)
* Check the feed and branches for gas. If pilot lights are not on then there is a good indication that your not getting gas to that section. (or the pilot is clogged) Clean, clear, or replace pipes/parts.
* Check valve on each burner. This is the most used item on the stove. Expect it to wear out. Replace as needed.
* Final, Be safe; Call your Gas company or MFR tech for service.
Aloha, ukeboy57
PS check youtube for: "Sears Kenmore Gas Oven Problems"
Ignition
hi,
when you have the burner head on the stove look at where the igniter (sparker) is, in line with that should be a hole in the burner head, make sure that is clear. also make sure the burner heads and caps are lined up properly with the igniters.
Loc message on
Program a clean cycle then cancel after it begins.
Eric
If this fails to clear it post your complete model number and I will look at the manual.
No gas to oven and burners, only one burner sparks
For burners, the sparks should fire vertically upwards. If not they wont light gas. If the other three are not sparking, and this problem started at the same time. replace the spark module. If the sparks failed over time, replace the spark switches which sits on the shafts of each burner.If no gas to oven or burners, your problem is the gas supply...to the gas valve or leaving the gas valve.This repair would be for a trained person.
