Have threaded needle and out bobbin in checked tension etc. when plain straight stitching the thread pulls out of needle. How do I correct this please?
If you haven't already, install a brand new needle. Be sure to use good quality thread--no old stuff or bargain bin variety.
Remove all the thread from the machine.
Raise the needle until it is at the highest point it will reach before it begins to lower.
RAISE the presser foot and rethread from the beginning--verify the thread path is correct. Pull at least 5 inches of thread tail through the needle.
Check that the bobbin is installed correctly.
Set the upper tension to somewhere around the midway point between high & low number.
Pull the bobbin thread to the top of the fabric:
How and Why to Bring up the Bobbin Thread
When you begin to stitch, gently hold both thread tails with your left hand and begin stitching slowly to start.
Why does my thread keep pulling out of needle
Tilly and the Buttons Five Common Sewing Machine Mistakes How to Fix Them
