Checked continuity of motor good. one of the power leads going to the speed control has a break.
A broken part ? or is only the potentiometer of the speed control thats damaged, but a wire that is broken ? without any force is hard to believe the spring element internally that moves along the carbon track of the potentiometer inbetween the speed control should have lost the contact pressure or only dirthy ?. where the resist for rpm mixing is lost. maybe marketing technical made to order it as a one-part assembly try contactspray in the potentiometer.
SOURCE: Broken Cord
Sometimes there are hidden areas under the products name plates where they need to be gently pryed off and other times usually in the least exspensive types they are just snap fitted together and you will need to gently pry apart at the seams!!
Model number please.
The Food Mixer is a Sunbeam Mix master 12 speed stand Model #MM97
am
