The brushes on my vacuum have stopped turning
SOURCE: Dyson vacuum cleaner-brush bar is frozen
Hi
If your Dyson has a brush protection design - i.e. roller bar on the top of the hood on the left hand side then the DYson can't be repaired by you- serviceman or professional care can replace it.
However if the Dyson doesn't have the roller bar on top of the hood, flip the machine over so that the beater brush is facing upwards, locate three/four screw heads that can be undone with a coin and remove the sole plate assembly. This should give you a clean view of the brush bar, drive belt and dirt channel. Ensure everything is clean espcially if the brush bar has lots of hair or threads tightly corded around. Then locate the drive belt and check to see if it has snapped. Grasp the beater bar gently upwards and the belt and brush can then be removed. Fit a new belt on carefully and check the tension as it will be tight.
Locate and purchase the correct belt for your Eureka vacuum cleaner from the local grocery or department store. Vacuum belts come in different sizes according to your model of vacuum. Check your owner's manual or the vacuum itself for your model number.
Turn your vacuum cleaner over so that the bottom of the unit is facing you. Remove the cover plate from the bottom by undoing the screws that are holding it in place with a screwdriver.
Locate the belt pulley rod near the back of the vacuum base coming out of the motor. With the vacuum cleaner base turned upside down and facing you, the motor and pulley rod should be up near the top of the base.
Slide the vacuum brush roller out of the slots at the bottom of the vacuum base and remove the old belt from the brush roller and pulley rod. With the brush roller off of the unit, clean the brush by removing any strings or cords wrapped around the tube.
Install the new belt by looping it over the belt pulley rod next to the motor and then looping around the end of the brush roller in the belt slot. Hold the brush roller and pull back on it to tighten the belt while you slide the roller back into the slots on the vacuum base.
Replace the base cover plate by snapping it back into place and securing it with screws. Turn vacuum back upright and turn it on to test the belt and verify the unit is working
