10w30... And I use ONLY Kohler 10w30 in my customers Kohler engines.
Now the hydraulic system in the Woods mower most likely uses a 20w50 MOTOR OIL but it's been about 5 years since I have even seen a Woods unit. www.woodsequipment.com
There will be a switch that changes state when you get off the mower. Your weight is supposed to enable the engine to run, and when you get off (or fall off), the engine is supposed to quit. Look for wires to the seat assembly, and look for frayed or broken wires or sharp bends in the wire(s). Good luck!
check your tire shear pin frist and check your idle pulley too, and belts. also check to see if your unit has cables to the hydro. if so one might have broken. if all looks good, its more likely an axle problem, call your local service center
On most phones, you'll go to: Settings > Connectivity > Bluetooth
> (turn
on) > Phone visibility (shown to all / on) > Search for devices
>Choose headset (when located)
The password is 0000 (four zeros)
One this to try is a hard reset: unplug and wait for a few minutes and re-plug back in. Sometime this resets the service condition and will then display the error codes.
Ice is displayed when the ice maker is turned on. Press the ice on/off and it should turn off.
If you mean no dial tone when you take it out of the cradle, I have run
into this. The solution is to unplug the power cord and then plug it
back in which resets the unit.
