Hi The ignition for the gas hob has stopped working my old oven was just a battery that had to be replaced. I have replaced all the fuses in the wall sockets in case the ignition runs from the mains with no joy. Any other solutions would be great?
SOURCE: fan oven on zanussi electric cooker does not heat up
From symptons, I would say the fan oven element is faulty, more so if the fan is working. Remove inner rear panel of oven and see if element gets warm, let it run for a minute, switch off and feel if element is warm, if not, then replace.the element.
Plz rate this solution.
Thanks.
SOURCE: zanussi 360 just tripped and now keeps tripping
You will probably find that it is the oven element that needs replacing, located at rear of oven compartment behind rear panel.
Please rate my solution.
Thanks.
SOURCE: fan in main oven boken
Sounds as if your oven heating element has failed. You need to fit a new one.
Usually you have to get the back off, disconnect the old element, remove the fixxing screws and element, fit new one, reconnect and it should be fixed. Don't forget to switch the power off before starting work.
SOURCE: Faulty main oven
If the fan is working in the oven, and it is electrically heated, then it will be a faulty oven element.
This is located at the rear of the oven behind a removeable cover.
