SimpleTech SimpleDrive Pininfarina 320GB External USB 2.0 Hard Drive - Blue Logo
E
Emma Koeberl Posted on Jun 02, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
When I plug my harddrive into the computer everything freezes up instantly! help
Level 3:
  • SimpleTech Master 19,187 Answers
  • Posted on Jun 02, 2016
SimpleTech Master
Level 3:
Answers
19187
Questions
0
Helped
4346430
Points
82261
Try it on another computer, if it happens on the other computer then the hard drive is bad.
1helpful
I play my xbox 360 and it freezes at the beginning part when it loads. It never goes to the dashboard.i took out my hardrive and played it again and it works,if I put my harddrive in, it freezes.
Your harddrive is corrupted you would need to reformat it but this will wipe everything that was stored on it. You'll have to start it obviously with the drive out and install it then go to system settings/memory to reformat
2answers
The harddrive was connected with my pc, but it was all turned off. a short circuit must have happened that day, i found the harddrive turned on. probably the arriving electricity turned it on, (it often...
Probably not the right answer for your problem. Mine is an external 1 TB Simple Drive. Mine wouldn't respond at all. I unplugged the power cable from the back of the hard drive and replugged it in and instantly it worked. I had tried rebooting the computer, plugging/unplugging over and over into the computer and that didn't work.
I have a WD1600 Extrernal Harddrive and yesterday my kids unplugged the outlet so everything powered down instantly. Once I plugged everything back p and restarted my computer the harddrive just spins up...
The hard drive could have been irreparably damaged. The chattering sound is the heads trying to find the beginning of the data sectors and can't. The drive will shut itself off automatically after a predetermined time period.
I was restoring the system in my laptop and I have forgoteen to unplug the external hdd toshiba 120 gb mk1234gax hdd2d16. After I have choosen to restore the system of the laptop have initiated, I...
it sounds as that you have flashed the usb port. take the harddrive to someone with a computer and plug it in theirs. if it still does not work remove from case and plug the harddrive straight in to yours.
Seagate 1.5TB dropped from office table... TWICE.
the drive is damadged internally, you have to phone or email a data recovery centre to get your data back, that can cost $1500+ because of the size of the disk.
2answers
The graphics are freezing. The problem persists
What type of ring? 1 quadrant? 3?
If it's NOT the 3 ROL (aka the "red lights of death" which usually means something wrong with the console's motherboard), it maybe something as simple as a loose video connection. Take apart EVERYTHING (including the harddrive).
If it still freezes after the reconnection, first try performing disk drive maintenance, which is located in the memory section of the options menu (goto my xbox and press right on the analog stick until you reach SYSTEM SETTINGS). Once you've done the disk maintenance/cache clear try playing some more to see if it freezes again.
If it is STILL freezing try playing it w/o the harddrive. Not all games can work w/o the harddrive, but if you can verify that it's the harddrive causing this then you know it's the HD and not the console it self.
That's all I have. Hope this helps,
Bill
Windows XP will not recognize my WD 250GB Harddrive
Just plug your USB HDD directly into your MBoard's USB port...
Everytime LifeCam is plugged into USB port computer freezes
Normal 0 How much memory do you have installed in your computer? It may need to be increased as this is likely to be the cause of your computer freezing.
Hope this is of some help. Bud
Acer aspire 5050 freezes when external HD plugged-in
if the simple tech is still in warranty I would return it to the seller as not compatible with your computer you want to use it on.
otherwise you could reference the acer faq to see if this is a driver issue.
Another possibility is to see if the fire wire card has updated drivers*(I assume that is the port you are using?) and you could also get a fire wire to usb converter. or try changing the connection on the simple tech a slower serial speed, this may be the trade off to use this item.
Top SimpleTech Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Alexander
ExpressFiX
ExpressFiX
Are you a SimpleTech Computer and Internet Expert? Answer questions, earn points and help others
